EBU radio feeds
7mdish
Milan, Italy
Anyone has updated information about EBU radio (not TV) feeds? Are they broadcasted by satellite or fibre? I refer particularly to live classical music concerts, but also news and sports. Regarding classical music, there is an EBU service named Euroradio used to broadcast such live concerts from many european locations, rebroadcasted to listeners of many public radio stations in Europe (BBC in UK, RFI in France, RAI in Italy and so on). Some years ago these feeds weree on Eutelsat 7 East distributed through a proprietary, narrow-band, non-DVB system (symbol rate lower than 2 mb/s I believe). Now I don't know, fibre maybe? Any advice? Thanks.
Adam792
Cheltenham
Interesting question, I've wondered this before too.
I've just searched and couldn't find much information except this interesting presentation from 2010 - Euroradio
This talks about replacing the 16 year old previous system with a new DVB-IP system using DVB-S2 with a low symbol rate (DVB-S2 8PSK SR: 365 FEC: 3/4).
If the screenshot in the presentation is of the actual 'live' replacement system, and it's still in use now (11 years later, but the DVB-S2 IP system remains fairly up-to-date!), plus we assume that the satellite in use is still Eutelsat 7°E (I think this is likely considering it is used for other EBU feeds still), then the frequencies in use are potentially -
11024.45 365 DVB-S2 8PSK 3/4
11025.25 365 DVB-S2 8PSK 3/4
I can't see the polarisation mentioned, but there's only H and V to try! Can anybody see any sign of these on 7°E with a PC card in something like Crazyscan?
The only problem is that the codec used for the audio is aptX by the look of it, which isn't decodable using consumer receivers. It's possible that this could have switched to exclusively IP distribution by now of course though.
7mdish
Milan, Italy
Could anyone confirm all this? At the moment I'm not able to perform any test because I'm waiting for my new dish (just ordered a 2.4m).
When the dish will be here, I can try with my TBS5925 PC card and maybe (not sure) I could have little chance to make some tests using an old RX8200, but I don't think that box includes APTX codec, and I don't know which professional receiver support it. And, what about NS4? Any possible switch to Novelsat after 2010? Thanks.
SimonE
Gloucestershire, UK
Nothing seen this morning on those two frequencies H or V. The three Eurovision News feeds are there and active. There is a signal s/r=1905 ACM/VCM just below the news feeds 11041H. Just above the news feeds there's four narrow signal-roughly 1mhz each.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
I can also see that freq at 11041 but no idea what it is sadly.
Hi Adam792,
For the moment I am not with the antenna at 7.0E,but I will move soon to 11024 V,365,3/4.
But this transponder is not new, I found it in 2015 and then I made some recordings with this stream. Fortunately, this file I uploaded here.
I hope you can use it and, who knows, maybe you can find out more information about this stream.
Best regards :)
7mdish
Milan, Italy
The signal at 11040H SR 1905 is active from years but I was never able to decode nothing. I believe it is some data stream not related with EBU. As I said, I can not test yet.
I checked 7.0E trp 11023/11024/25 V,365,3/4.Unfortunately it is no longer active, instead there is now a feed.
In fact I was expecting not to find it, because in the last few years I have not seen it on the analyzer.I t is true that I have not searched it as I should have, but with the very strong signal I had six years ago I should have found it easily without digging deeper. Back then this trps had the Verical polarity. Trp. 11024 V,364,3/4,8PSK disappeared with the change of Eutelsat 7A.
From my experience with feeds, I can say that usually providers don't keep a radio stream for long, especially with low symbol rate, on a satellite with a large number of feeds, between 10950-11700 MHz, like on Eutelsat 7B/C or Eutelsat 10E.
So it's not to be found now.
If you think it can console you for the lack of 11024 V, then try 11568 V, 17016 V, 2/3, where you will find a package of radio streams. Strong signal on this transponder.
7mdish
Milan, Italy
Perhaps checking during a live concert broadcasted by Euroradio could be a good idea. Sometimes it happens on Monday evening starting with Autumn season and during the Winter, or during special events like BBC Proms or La Scala theater opening on December 7th or Vienna New Year Concert and so on. During these events there are surely such Euroradio transmission.
