Eutelsat 5 West B - reception reports
Pepeyeb
Eutelsat 5 W B con antena de 1m.
Receptor de satélite Octagon SF 8008 twin. Dreambox Two.
Toledo (España)
Hi
The transponder 11179 V in 5ºW is off (MIS Italians)
Anyone know what happens?
No signal here either :(
Just have to wait and see if it returns or pops up on 9°E.
LateAdopter
80cm fixed, 4 position switch
28.2 E, 19.2 E, 13 E, 5 W
Xoro HRS8500, Edision Primo
They have had notices saying that the SD switch off is 20th October and everybody will need to retune. I assume this means the channels like RAI movie will be HD and they will be rearranging their transponders.
Thanks! Changing SR to 35300 works on the Primo :cool: :Y
That it do (TP rescan required)
Strength 82 Quality 98
"Better than Bilsdale"
Pepeyeb
Toledo (España)
Try with 11179 v 35300 3/5 mis 4, 5, 12, 13 gold 131070
or root 16416.
Thanks.
Now it looks good.
There is some difference between putting 35300 or 35293 (the latter is said in an Italian forum).
11179 V,35300-new symbol rate
