Pimp up Channel Master
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Got laser-cut plate and couple of letters engraved on it. Perhaps I polished it too much so letters are not so visible anymore.
samoloko
1.8 PFA
EU
Rima
fabulous work, thank you
would you please explain what Is difference In positioning between your lnb holder from post above and original channel master lnb holder
does your holder support original ChM 1.2 arms at same height fixing only lnb angle facing not center of dish but bellow
RimaNTSS
N-E from Riga
Alex! Yes, the new holder goes directly to the original CM feedarms. After installed, it gives possibility to position LNB exactly how the original (plastic) holder does. But, in addition, it is possible to change the position of the LNB up/down, change the aiming point, and, of course, change the skew.
Manikm909
Small'ish Dish Man
Kent, UK
@RimaNTSS - nice work - question: i seem to remember you saying that the arms are not the correct length for optimal setting.
so do they need altering too in addition to this new whizzy LNB holder>
RimaNTSS
N-E from Riga
No, the original CM feedarms are at the correct length. But, in fact they should be at different length if you wish to switch from universal LNB to original CM feedhorn. It is still much better to have original feedarms replaced by length-adjustable ones. It is always better to have more flexibility.
samoloko
1.8 PFA
EU
Rima,
thank you for reply
Am I right to say that location of lnb for original arms and plastic holder for ChM 1.0, 1.2, 1.8 Is correct, but there Is only Issue with lnb pointing to center of dish Instead of slightly down to get better signal level
RimaNTSS
N-E from Riga
More or less yes, correct.
