- Jan 7, 2009
- Age
- 58
- Some SAT-related hardware.
- N-E from Riga
I thought I've seen a majority of your antennas, but what did you mean by "CM Gregorian"1 x 180 cm ofset plastic CM Gregorian;
OK just CM / copiefd from Радикал-Фото: Картинка /I am sorry to hear that Denis .... yes it is 1.8m plastic antenna (Poliship Canada, if I remember right), but it has never been CM and even more it is not Gregorian type. However, it can become Gregorian if you manage to attach the sub-reflector to it.
Yes, on the radical picture there is my 1.8m Channel Master antenna equipped with sub-reflector at the moment the picture was taken, that is why I labeled it "CM 1.8m Gregorian". But that is not the same dish you got. I am not saying the Canada Poliship is not a good one, it just not the CM one.OK just CM / copiefd from Радикал-Фото: Картинка /
Welcome to this great forum. You will surely benefit from the brains on this forum. But don't hesitate to give the group what you know and have.Hello, everybody to all member ,Just discoved your forum
looks nice and friendly.
I'm owner of div. VU+ (Original)
VU+DUO - Broken
VU+SOLO SE - OpenPli 7.3
VU+SOLO2 - OpenPli 7.3
VU+UNO 4K - Broken
1 x 110 cm ofset
how are they "broken"Hello, everybody to all member ,Just discoved your forum
VU+DUO - Broken
VU+UNO 4K - Broken
1 x 110 cm ofset
Hi manikm909 , yes i've 2 units VU+DUO with signal recception problems and i know the problem , I have found in other forums this note: change some capicitors ( c848 and c819 ) to get it to work.how are they "broken"
personally i wouldnt bother trying to fix the DUO's but everyone is different.Hi manikm909 , yes i've 2 units VU+DUO with signal recception problems and i know the problem , I have found in other forums this note: change some capicitors ( c848 and c819 ) to get it to work.
I've also an VU+Solo broken, i can't see nothing, just an red diod in the front of the box.
And finally a VU+UNO 4K which switches off after 15 - 30 min. work .
Do you have any idea what's a problem ?
Thanks in advance
Sure manikm909, that's exactly what I want to do, i'll fix it and sell it then.personally i wouldnt bother trying to fix the DUO's but everyone is different.
i sold my working one for 40 quid. if u can solder the new caps in, then maybe fix and sell
what do you do to your receivers? you dont put them in the dish washer do you>?
