frankviana
- Jan 10, 2006
- Age
- 42
- Satellites/tv
- Brazil
Tell me the name for this skin and which stb, please.
Thx
Skin is nBlack6 (from 2boom) of Octagon SF8008 with OpenATV 6.4Tell me the name for this skin and which stb, please.
Thx
@ 47.5 West
3898 R. 4936. 3/4. DVB-S2. 8PSK FTA Feed.
From Kourou - Web Space Telescope.
View attachment 139905View attachment 139906
man! 80% - i came across these earlier around 55% i think....my dish is now stuck on 61w - my silly VBOX cant move it back east - job for the morning....usually my Jaegar has enough ooompf to do it.
@John - wise words, thanks, can you upload a pic of what you mean, i cant picture it. thanks!A counter weight on an extension off the rear of the dish will help a positioner or actuator cope better with getting back from extreme outer arc positions.
I use one now on my 1.2 Gibby thats loaded up with five different band lnb's on a 'changer' and i used one on a 1.8 CM loaded with lnb's on a changer in the past .
My 2.2 PF has a fair old bit of weight hanging up front with the C-band motorised poloriser / scalar motor stuff and this makes the 'Venture' 36"er and the RC2000 grunt a bit when coming off of the extreme arc edges so was thinking about adding a counterweight to that as well this summer perhaps.
At 55% signal level on the GTMedia you are doing OK.
Remember, @John is using a 2.2m Elite Antennas prime focus dish with triple axis motorisation, a Prodelin rib tickler and he is a master of his craft.
He will be as peaked on 55.5W as it is possible to be and I doubt if anyone else in the UK could match his signal levels with a 2.2m dish.
Dont get disheartened, you are doing well for a first dip into C-Band, especially considering the 80% signal level of @John is coming from a dish with approximately 50% more surface area.
You have done infinitely better than I have from 'ere on 55.5W, I aint got line of sight to the bítch. Or rather, it is so blocked it's as much use as a wet fart down a drainpipe, I think I got 0.9dB on one frequency.
Forward Men...
he does have a way with words doesnt he.
