Terryl
- Apr 14, 2011
- Age
- 82
Custom built PC
- Deep in the Boonies in the central Sierra Nevada mountains of California.
Is the drop in reception affecting the quality of the picture???? If not then don't mess with it, the signals are now digital, you don't need to get every ounce of signal possible to get a clean looking picture, now if you having signal drop outs, or picture quality problem on the end LNB's then yes a re-alignment would be needed.
Remember, the signal strength indication (S) on the receiver is measuring the signal coming down from the LNB's output, and the quality indication (Q) is calculating how many bit errors in the signal that have to be corrected, the lower the Q the more bit errors are being corrected.
