22w Ses4
Lasseparabol
3 m Prodelin
C band 25K Chaparall Sidekick
Ku band SMW X-line lnb
Chapparal Corrotor 2 Wide band
Echostar AD-3000IP
Dr.HD F15
Sweden south part
Some radio channels at 3695R 1413 only 9.1dB and some breakups in sound.
No TV channels.
nelson_b
Contributor
hi -
just to compare from this location --
7.1 db -- good lock (no audio breakup) - it only scans as 1 radio channel for me -- id = VTC NSS7
cheers nelson.b.
pride21
Sandown Isle of Wight
same here nelson with 53% quality.
BlindFaith
TBS 5925
..only 9.1dB and some breakups in sound.
9dB should be more than enough. The threshold for quasi error free reception is about 4,5dB with FEC=1/2.
The culprit is probably your LNC which produces too much phase noise to get stable reception at this very low symbol rate.
Kveys
Southern Finland
22W 003.JPG22W 002.JPG22W 001.JPG 22W 004.JPG Emmanuel Tv (4141L) 24/7 watchable. 3943L 2 other religious sometimes watchable though allways some kind of signal. BBC radio sure also Ok. Never any signal from Ghana but low sr and 8PSK is poison :)
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Scan this morning 12.30hrs:-
Afternoon scan 17.30hrs:-
Although some below were missing from the first auto scan a second scan locked them!! anyway manually scanned in:-
3695 R 1412 Radio - BBC World Service....at the mo pre-recorded music loop (zip attached)....earlier was studio discussion.
4097 V 23500
Best was 3726 L 1002 - Viasat 1 - Ghana
22.0W_3726,556_L_1000_(2015-04-10 16.45.30)_dump.ts_000005109.jpg 22.0W_3726,556_L_1000_(2015-04-10 16.45.30)_dump.ts_000003586.jpg
4141 L 1925
3826 L 8950 - Smile of a Child
  • VTC NSS7 noevent 20150410_171538 #1.zip
Today's scan - manky outside today:
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Hi Chris1979,
I can confirm your scan from position 22.0°W.
3662 R seems changed SR, according your scan.
Best Regards
qwer.
Scan result table for 22.0W attached below.
The frequencies and broadcasters may have changed a little since the last contribution to this topic two and a half years ago?
There are quite a few data transponders that I excluded from the table. Also, I was getting a signal at about 4.1 dB, below the level for a lock from 3974 L which is listed as on the West Hemi beam. I am quite a way out of the footprint for the West Hemi beam here in the UK so I am not sure if it is a true signal or some spurious artefact?
dreamsat
germany
the small audio carriers from "Radio Maria" with the IQ Monitor
stephan94
Bavaria
I also managed to receive all nine frequencies with "radio maria".
with 1.80 it is very limited.
I don't know if another program can give this result.
Satfaca
Melmac (46N, 14.5E)
DM920 + Octagon SF8008 + TBS 6925
Melmac
Latest stand in the Easy TV Côte d'Ivoire MultiStream package on 3.748 LH.
There's also MS 174 with a couple of radio channels but all encrypted.
dreamsat
germany
my scan
