Newbie Here Dish size for Astra 28.2E, Astra 19.2E and Hotbird 13.0E
The mount of the Triax TD110 was designed by an octopus - you need at least three arms to adjust the bloody thing correctly, and when you do the nuts up it throws the set up out. It really is a nasty bit of work!
And your installer was talking complete ballcocks about it not being suitable for multi sat - Im running one on 46E with multiple offset lnb's and its fine.
sectoid1
none at the moment
Manchester
No idea, maybe he hasn't done a similar installation before. Maybe I'll fine someone else.
So what do you think about these?
http://www.ebay.co.uk/itm/3-Fold-Mu...121?pt=LH_DefaultDomain_3&hash=item3aa5a41521
http://www.ebay.co.uk/itm/4-Fold-Mu...179?pt=LH_DefaultDomain_3&hash=item3aa3be55cb
They should both be fine for TD88 and Gibertini, right?
If I go for Gibertini, I think I'll get it from Germany. Well, I'll probably get most of the stuff from Germany as it's a bit cheaper than in UK, even with delivery.
daro2096
No setup at present
Consett, Durham
Up to you Sectoid1 but I think 1m+ dishes are overkill for what you want. Have you thought about the Cahors/Visiosat Big Bisat dish which can do at least 8 or more satellite positions? Talking about £180 from Germany with addional lnb brackets plus you can achieve 3 degree separation with 3 degree brackets. HM Sat in germany sell them for €8(additional brackets(£5)) each plus the dish is not steel so will not rust with time.
digi247
NW
see sig
Just to let you know i cover the manchester area if required and as you can see from my Sig an 80cm would suffice adequately, a picture of mine
sectoid1
none at the moment
Manchester
Thanks! That's why I still think about TD88. If it's a good dish, I probably get it. Daro, Visiosat is a bit expensive to me, but thanks for suggestions :)
So does it mean you would be able to help me install the system? :) If so, it sounds great! How much would you charge? :)
Nice quad you have there, btw :)
There you go - wait long enough and your Ship will come in! :)
daro2096
No setup at present
Consett, Durham
I had a technosat 85cm steel dish up for 4 years and at the end there was signs of rust on the dish.
Easily resolved with a coat of Kurust.
Mind you, it'll take forever before there's an impact on reception!
My cheapo Orbital 80cm started rusting around the rim within a couple of years, but even now, several more years later, it works absolutely fine.
daro2096
No setup at present
Consett, Durham
My rust was around the screws in the centre. The rust was running down the dish.
Still won't affect performance, but any offence caused by unsightliness can be remedied with said Kurust.
daro2096
No setup at present
Consett, Durham
A little difficult when said dish is 20 feet off the ground or so.
I use ladders ;)
daro2096
No setup at present
Consett, Durham
I have a thing about heights ;)
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
daro2096
No setup at present
Consett, Durham
That should read Technomate.
sectoid1
none at the moment
Manchester
digi247 is helping me with this a lot and had few good suggestions. Thanks digi :) I'm hoping he'll install the system for me in few weeks :)
daro2096
No setup at present
Consett, Durham
Sectoid1 if you haven't bought your dish yet I could sell you my unused visiosat big bisat dish if you want to travel to collect it. If you are interested pm me. I have decided to not install it, too expensive I have decided.
sectoid1
none at the moment
Manchester
Hi all :)
I just received a dish (Gibertini - delivered from germany) but it looks like it's been damaged a bit - it's got a dent. Have a look:
Front:
Back:
It looks a bit worse on the picture than in reality, but is this going to be a problem? Can I repair it somehow whitout sending it back to germany?
Retired Mod
www.timo.me.uk
Hi all :)
Front:
View attachment 76427 View attachment 76428
Back:
View attachment 76429 View attachment 76430
Aargh, it's so annoying when this happens because the dishes are not sent in suitable packaging. I had a similar issue a while back with a dish I mail ordered but luckily the supplier was happy to send a replacement dish face without wanting the damaged one back. Here's my story:
https://www.satellites.co.uk/forums/threads/damaged-dish-what-should-i-do.162322/
sectoid1
none at the moment
Manchester
I've managed to push the dent back a bit. Still looks a bit unnormal though, but not a visible as before.
However from your "story" post, timo, I noticed you couldnt see a significant difference between damaged and new, so maybe I should't worry too much?? It's a 1m dish. What do you think? (By the way, timo - nice balcony set up :) )
Anyway, I sent an email to the seller in germany. I'll see what he says.
