46.0ºE AzerSpace 1 / Africasat-1A scan
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
46.0ºE AzerSpace 1 / Africasat-1A scan.
Special one this for me:- :-applause
a) new sat to add to the list!
b) Where we are located ....never been able to lock a transponder on the Ku-Band Europe beam.
Really really pleased......especially as is C-Band.
Just locked it so when I have time will fine tune and hope for other frequencies.
Perhaps you can help me a little as to why the four frequencies scanned in show a polarization of 'H' when we know they are in fact 'V'.............I have read that for 'H' and 'V' scanning the the dialectric plate should be removed.....thanks.
A slightly earlier scan gave also 4025 H 1190 (again should be 'V').
Channel 'Celebration TV'
The plate should be removed like you say for scanning linear polarity, else you get illumination on both probes (H and V). If there's no plate in there, then you just need to rotate the LNB 90 degrees.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Rotation explains it...........input appreciated.....here, learning curve. :)
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Thanks CJ......todays scan after your tip has done the trick. :-applause
Archive-8
All I can get at the moment with a 1.25 dish.
[SATTYPE]
1=0460
2= AzerSpace 1 / Africasat-1A
3=3
4=0
5=5150
6=0
[DVB]
0=1
1=3844,V,12630,34,132,|-46 dBm, 6 dB
Archive-8
Using the 1.5 Dish.
[SATTYPE]
1=0461
2=C-Band AzerSpace 1
3=3
4=0
5=5150
6=0
[DVB]
0=27
1=3440,V,1344,56,1,|-59 dBm, -10 dB
2=3730,V,29990,34,6,|-48 dBm, 5.3 dB
3=3730,H,29990,56,132,|-48 dBm, 4.4 dB
4=3759,H,11680,56,134,|-51 dBm, 5.8 dB
5=3771,H,2792,45,132,|-51 dBm, 2.6 dB
6=3833,V,1076,23,6,|-52 dBm, 3.3 dB
7=3844,V,12630,34,132,|-52 dBm, 4.8 dB
8=3845,H,7298,?,4,|-52 dBm, 4 dB
9=3857,H,2945,34,5,|-52 dBm, 2.8 dB
10=3861,V,1665,23,132,|-52 dBm, 5.8 dB
11=3864,H,3090,34,148,|-52 dBm, 5 dB
12=3884,V,12380,34,132,|-54 dBm, 2.7 dB
13=3890,H,29990,56,132,|-51 dBm, 5.7 dB
14=3919,V,10410,34,150,|-54 dBm, 3.2 dB
15=3930,H,32990,?,4,|-52 dBm, 4.6 dB
16=3956,V,5498,89,5,|-56 dBm, 2.1 dB
17=3970,H,33500,23,0,|-53 dBm, -10 dB
18=4000,V,13480,34,134,|-55 dBm, 1.3 dB
19=4010,H,32990,34,132,|-53 dBm, 4.6 dB
20=4025,V,1189,34,134,|-55 dBm, 4.1 dB
21=4041,H,14160,23,132,|-54 dBm, 4.1 dB
22=4075,V,2915,89,133,|-55 dBm, 7 dB
23=4104,H,1319,56,133,|-55 dBm, 2.8 dB
24=4138,V,13330,?,4,|-52 dBm, 5.2 dB
25=4138,H,13330,?,4,|-53 dBm, 4.6 dB
26=4160,H,15000,89,133,|-52 dBm, -10 dB
27=4160,V,16310,78,0,|-54 dBm, 5.9 dB
pride21
Sandown Isle of Wight
hi all tried this sat this morning on 3730V there is reuters,mtv base Africa,dd podhigi,dd sayadri,dd saptagiri,dd Urdu got this at 8.9db with rain I think these are from Amos 5
nelson_b
Contributor
Thanks for the info - pride21 -
indeed it seems they are channels from Amos 5 -- nice to have these now - hope they stay :)
they have always been out of reach for me at 17 East
good signal for me here on 1.8 cm -- 10.5 db
Ah so Spacecom are punting channels to where ever they can find suitable capacity after Amos5 failed.
nelson_b
Contributor
No lock on this transponder for me here ... only getting 8.4 db :(
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Freq 4050 is stronger than 3730V. This screen shot is on 4050V. although 3750 V is showing a healthy 9.75 db.
Archive-8
[SATTYPE]
1=0461
3=4
4=0
5=5150
6=0
[DVB]
0=31
1=3730,V,29990,34,6
2=3730,H,29990,910,132
3=3761,H,13600,12,149
4=3767,V,1665,45,148
6=3784,H,1940,45,132
7=3810,V,999,34,132
8=3819,H,5176,56,132
9=3826,V,4165,45,148
10=3833,V,1076,23,6
11=3833,H,1407,?,4
12=3835,V,1077,56,6
13=3844,V,12630,34,148
14=3845,H,7298,?,4
15=3857,H,2945,34,5
16=3865,H,1967,34,148
17=3884,V,12380,45,133
18=3890,H,29990,56,132
19=3930,H,32990,34,132
20=3945,V,3107,23,132
21=3956,V,5498,89,5
22=3969,V,1343,56,5
23=3970,H,34270,?,4
24=4000,V,13480,34,133
25=4010,H,32990,34,132
26=4025,V,1189,34,134
27=4026,V,1199,34,134
28=4041,H,14160,34,132
29=4050,V,29990,56,6
30=4075,V,2915,89,150
31=4086,H,13810,34,5
nelson_b
Contributor
4050 V 30000 5/6 (from 17°E) also available on 3730 V has already reported
View attachment 87985 View attachment 87986
hi --
The Indian channels have gone from ... 3730 V :(
and 4050 V 30000 .. (not listed on flysat)... is below lock for me here.
do you know if the channels are still there on 4050 v or have they perhaps moved to another sat ?
regards . nelson_b :) .
Anonymous_1
4100 H 300 2/3 Radio "Tandabui Health" from Tanzania
4186 L 2930, 2 programs now
Promo (very bad quality) and the 2nd called 'Azerspace 1' the logo is SABZBAAT BALOCHISTAN from Pakistan
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Small SR and video content:
3775 H 770 2/3 DVB-S2 8PSK, Heritage TV
