tobikk
- Jul 27, 2016
- Age
- 30
- Echolink el-3060 vs super and/or X2 Square M1
- Birmingham UK
Hi there,
I'm kinda new to this forum and I need your help / advice regarding this channel on Hotbird 13E Sat.
Kurdsat HD
11373 Mhz
27500 H
Fec: 3/4
This channel moved recently to above frequency and I have managed to bring it back. The only problem is I do not receive video just audio. Problem exists only on this channel. I have checked it on X2 Square M1. I know it's an old one receiver, but also I have checked it on Echolink El-3060 and there this channel shows as a radio not a tv channel. Also I have brought and check my friend sat receiver and everything was fine there. I don't know the name of that receiver. So my only thoughts on why this is happening are that these 2 old receivers can't stream HD channels, but I might be wrong so I need your advice before I jump to buying new tech.
Also I'm not sure if this is a correct subforum for this kind of questions. Sorry if it's not.
Thanks a lot,
kind regards.
Kurdsat HD
11373 Mhz
27500 H
Fec: 3/4
Thanks a lot,
kind regards.
