- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
Will they play earlier PS 3, 2, 1 designated games ?
unless these things have another use.
Thanks again (I think). Does the PS4 not play BluRay/DVD as standard then ?
Forgot to ask (though I think I already have the answer)
PS3 wireless handsets, compatible with PS4 ?
Thanks, I picked up a Dualshock 3 from a charity store over the weekend for a couple of pounds. It looks like it has the same number of buttons (with the exception of the scroll pad near the front).
I'll look out for the BetterDS3tool in the next few days.
The buttons are there, yes, but in the eyes of the playstation, the PS3 pad will be a "Generic gamepad" on a PS4 and vice versa (like I said, I've tried it!), things like the variable-pressure trigger paddles (L2 and R2) don't work properly and just act as plain buttons, which makes 'em a tad useless...
As you mentioned , it might come in handy for the PC. I already had an idea it wouldn't do much else. Probably why the ps4 controls are around £40 and upwards.
