Idiots guide to using dvbviewer
Ursa-Major
HI fiends,
Well i got a VisionDTV card, with no cam module attached...is it possible to view scrambled channels as well. Actualy i used ProgDVB and i downloaded the softkeys and stuff but when i view the scrambled channels it just shows black screen...can any one gimme a hand with this plz?:)
Ursa-Major
arihhh
ss2 computer pc
How can I enable Marfis Rendere?
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
Cheers Charlie, but I think he may have it sorted by now. ;)
(always best to check the date of the post you're replying to)
Rgds
L.:)
charlie46
Hello again
Did you manage to get the usernams and password to work..they wont work for me.
Cheers
Charlie
Lancelot
Retired Mod
SS1.
South central
Err... in what way ???
L.:)
charlie46
L.:)
As in "wrong password"
I have changed the * to other letters, I have even just deleted it."Wrong password"
Palapa C2
indonesia
hello guys i'm new here, i have Sky Star 2 card, but its not work on my computer, the message "error - ..... set turner status return error"
somebody know what's happened with my card?
yaraed
www.islam-qa.com
P4
CPU 2.8
winXp
SkyStar2
U.A.E
hi,
how can I capture ( picture ) with DVBviewer ?
thank s
HB13DISH
Retired Mod
Middle East - Israel
yaraed said:
hi,
thank s
If you record a channel, you can use another window application to capture any picture from the mpeg file that you make by recording.
I use Nero Showtime Player so check if your DVD player has the capture frame option also.
yaraed
www.islam-qa.com
P4
CPU 2.8
winXp
SkyStar2
U.A.E
thank you 4 carring !
I didn`t mean that .
as example : with DVB Dream thier`s option to capture live not recordering video , but with DVBViewer I didn`t found this option .
HB13DISH
Retired Mod
If you looked and didn't find the option, then it is possible that it doesn't have it.
yaraed
www.islam-qa.com
P4
CPU 2.8
winXp
SkyStar2
U.A.E
thank you again ,
I`ve skystar2 , which DVBplayer you think the best ?
HB13DISH
Retired Mod
ProgDVB
But it doesn't have frame capture.
yaraed
www.islam-qa.com
P4
CPU 2.8
winXp
SkyStar2
U.A.E
How many " thank u" I`ve to say to you 4 ur help ?
HB13DISH
Retired Mod
mdse2007
Skystar2 PCI Card connected to PC.
Having NileSat.
Remote not working.
No Serial Port, dongle conencted thru converter
Qatar
Somebody help me out..
I have a Skystar2 PCI receiver connected to my dell PC, which doesn't have a serial port. The dongle for the remote is connected to USB using the BF-810 converter. Will this have any problem using my remote. And if it works this way, how do i configure it work with dvbviewer...
New user
Terratec Cinergy HT PCI DVB-T; DVBViewer; ProgDVB
Andorra
Hello,
I followed Big Ted's tutorial, but I have a few problems:
  • I don't have a MdPlugins directory under C:\Program Files\DVBViewer\
  • Where can I find the softcam.key file?
  • I downloaded the utility attached (fun2md.zip) but when I double-click it, I get this error message: Run-time error '339': Component 'COMDLG32.OCX' or one of its dependencies not correctly registered: a file is missing or invalid
  • In the Filters directory, I don't have a SkyAVC.ax file
  • I didn't find any channels.dat from SoftCSA in the attachment
  • Where can I enable the Marfis Renderer?
  • Where can I find softcsa?
Thanks for your help!
Oadbylad
90cm motorised Fortec dish Skystar pc card
Leicestershire
Big Ted said:
Idiots guide to using dvbviwer
1> purchase and install dvbviewer software
2> download and install yankse in \MdPlugins subdirectory http://yankse.tforums.com/yankse/MDYankse-1-03.2- TT.zip (conax built in)
make sure subdirectory is named MDPlugins (MDP in capitals)
3> put softcam.key in the \MdPlugins subdirectory and in dvbviewer root dir (created using utility attached)
3> In the Filters directory, put regsvr32.exe (from Windows/System32), and drag and drop SkyAVC.ax to Regsvr32 to register it
4> put the channels.dat from SoftCSA (also attached) to the DvbViewer directory
5> ensure you have enabled Marfis Renderer
6> ensure you install softcsa attached in plugin directory
7> if you need ecm's they are in yankse.sid.cache in yankse zip
Off you go
Attachment: fun2md v2.1.zip
This has been downloaded 4 time(s).
Is there any chance that you Ted or some oneelse could update this tut as the version of Yankse is not obtainable ( or at least this numpty couldnt find it )and of corse some files in the tut are now not there or re named , it would also appear that in squence of instlation is different , i would get in touch with the aurthur lol but cant seem to find him
tph
3.2 metre with quad LNB for 28E with Pace 2600C1. 2.4 metre movable with Samsung DSR9500 & Dragon CAM.
Larnaca, Cyprus
Please, Please.
I too would love to see this thread updated.
Regards TPH
