s-band
- Feb 7, 2016
- Essex
It seems that the STV6120 has responses at fRX/3 and fRX/5. The /3 response is only about 12dB below the main and /5 is 20dB down. The result is that the spurious, high frequency, responses can interfere with low frequency signals. It doesn't matter if the upper channels are clear but when using something like a Sky Q LNB, channels below 11200 were up to 4dB below the expected SNR (tested on 1W). Using an ~850MHz LPF for low channels should fix it but I've not tried it.
