Horizon HDSM USB - Latest Firmware and software
Pagenslave
Sky Q
Stoke-on-Trent
Horizon have closed and stopped all support for their sat meters
Does anyone have a copy of the latest firmware, satellite lists and the software to install onto my Horizon HDSM v3 USB
Craig
vma
Portugal
vma-satellite.blogspot.pt
RX: 3 motorized DiSEqC-1.2 dishes (100cm, 110cm, 120cm) + 7 regular dishes.
Main receiver: Vu+ Duo + many others & IRD
TX: Modulators for DVB-S/C/T + Dektec Modulators
Field Meter: Emitor, KWS, Kathrein, Unaohm, Promax, Spaun, Rover Instruments, ...
Portugal
Pagenslave
Sky Q
Stoke-on-Trent
Thanks for your help
I can get the drivers, manuals and the cleaning tool but I am unable to download the firmware
Regards
Craig
All dates have no programming data in them.
cityaerials
Installer with horizon meter support
Coventry
I have this which should be the latest they did.
Please note the usb Plus was different firmware to usb
  • Firmware-HDSMUSBupdate0045.zip
Mubaiwa
Explora
South africa
I would like to know which one is this, the USB or USB plus
cityaerials
Coventry
this is the Standard USB, - I have USB Pluss to if required.
Mubaiwa
Explora
South africa
I will appreciate sir please, how can I receive it, my meter is currently having version 1.0Ba-0041.
Tom07
Horizon satellite and Terrestrial meter
United Kingdom
cityaerials
Coventry
  • Firmware-HDSMPlusupdate0045.zip
Mubaiwa
Explora
South africa
I'm also looking for South Africa last known transponder list
Tom07
United Kingdom
Thank you for your help
Stev
90cm triax fixed dish
Technomate1500 box
Co Durham
Hi everyone I am new on here and would appreciate your help
I have the Horizon HDSM V 2.5 meter
I used to update it when required
Then I used my old PC tower that blew up sometime ago I have a laptop now with windows 10 on it what will I need to install on it to enable me to plug my Horizon meter into it and update it
Thank you for any help and advice
Stephen
The correct later file, which is going to be increasingly difficult to find if at all.
cityaerials
Coventry
Stephen
Hi, To update older meter you will need a USB to RS232 Serial adapter and the com-RJ45 Horizon programming lead (see diagram). You can also get a third party USB-RJ45 programming lead. USB to Serial cable for Horizon & BirDog satellite meters - RJ45 8 pin | eBay
The satellite settings are the same as USB/USB Plus, however this meter can only hold 32 Transponders.
  • Horizon Serial Interface Cable.pdf
Tom07
United Kingdom
Hi all, What's the difference in Horizon and Birdog? Are the two compatible? Just curious when i saw Birdog.
EmilM
Zero4K / Triax 6 head
Netherlands
Hi, I'm looking for latest NL transponderlist, though I think since I need only for 6 satellites (Astra, Eutel etc)
every European list will do ??
