- Jan 1, 2000
- Location
- North Nottinghamshire.
You can use it as is for Band A use , L/R circ poloriser left on for any 42East Turksat Circular signals or remove the poloriser and bolt the scalar feed directly to the ODU body for 19.2East Ka Linear pol Newsnet sng feeds, a method of attaching the big lump in the correct position on the feed arms / lnb holder can be challenging. - the mods are usually just stripping it down to recover the receiver board, mod the OMT if you want, change the rx crystal etc etc and you end up with what you see in the previous posts - depends how tech savy you are in doing the mods.
