Listen Up Octagon SX88+
I loaded up the Open8 firmare direct from the Octagon website a fortnight ago as I was getting fed up with the combo video lag.
Quite impressed with it so far, though I only put the 4008 back on the shelf at the beginning of the week.
Somewhat confused to say the least!
Are you referring to f/w loaded onto an SX88+ or onto another type of Octagon RX?
FWIW again: f/w version 1.05.92 from 30th Dec now available and just saying "Important software update. Please perform"- I wonder what's hidden in that that Octagon aren't telling us about?<_<
tallkeith
Octagon SX88+ 80cm dish Technomate motor
Hertfordshire UK
anyone use the DLNA server to stream to a ROKU box on a remote TV?
or any other streaming stick??
I cant get ROKU to work - it sees the server but no streams from it
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
I recently bought a SX88V2 Dual which is comparable to the SF8008m (Mini)
The box runs very well with Enigma² and Define Os
1_0_19_2775_409_1_C00000_0_0_0_20230114131946.jpg1_0_19_2775_409_1_C00000_0_0_0_20230114132249.jpg
If you can install VLC you may be able to use UPnP to access channels from the SX88. It works on the PC version of VLC but the version available to streaming sticks may have fewer features.
What tuner does this box use?
suedschwede
DE
gService DVB-S2 Tuner
atef 0
Egypt
nilsat
eygpt
Thanks :cool:
Looks like a slightly wider IF range and large symbol rate capability but no S2X. I wonder if it is able to lock some of those very low symbol rate radio transponders.
I also have the same question
Is there any answer?
SimonE
Gloucestershire, UK
I have just done a firmware update on my SX88+ from 1.04.50 to the latest 1.06.04 . It sits in a cabinet next to my SF8008 and since doing the update my SF8008 controller controls BOTH receivers. I put version 1.04.50 on a USB stick to try and go back but it wouldn't let me. I surely can't be the first to have this problem. Has anyone else suffered this and what's the cure please.
Manikm909
Small'ish Dish Man
Kent, UK
Yes
See this thread
SimonE
Gloucestershire, UK
Thanks Manikm909. I will check that link tomorrow and see if there's any hope.
SimonE
Gloucestershire, UK
Thanks guys for your advice. My SX88+ has been restored to v 1.05.50 firmware. The problem of my SF8008 rcu controlling my SX88+ has now gone. Deep Joy!
Manikm909
Small'ish Dish Man
Kent, UK
nice one, its a shame you're forced to stay on an older firmware cos of this
