Tbs tuner and crazyscan - probably not a pc card issue
New StreamReaderEx BDA Tuner v.1.2.5.157 from 7.06.2023
TBS 6903X, 6909X support only FFTScan - so selection disabled and FFTScan always selected.
Could anyone please explain what the benefits are of FFTScan compared to RF Scan?
Looking at the FFTScan result earlier in this topic, the FFTScan yields spectra that look similar in style to those from the linux blind scan tool neumodvb?
deeptho
Europe
Yes, because both are fftscan. Linux version was first. Windows version exists for a long time as well, but was also worse in quality for a long time (perhaps fixed now)
Any benefits with FFTScan compared to RF scan?
deeptho
Europe
Water. TBS5927.
52 scanned, 21 locked.
Beer. TBS6903X.
106 scanned, 29 locked.
Beer (real ale?) TBS6522.
75 scanned, 29 locked.
Some anomalies in the TBS 6903X and TBS6522 spectra using the fft engines. Some multiplicities of various frequencies.
Also, I still get 50MHz spikes in the centre of a scanned spectrum with the TBS6522. No idea what causes that.
deeptho
Europe
Water. TBS5927.
Beer. TBS6903X.
To add to the discussion and to be absolutely sure, I performed an experiment:
1. open garage door to have clear view of the car
2. drink a beer (regular pils)
3. check if the car was driving: no.
4. check for cirosis: no.
Of course, it is dangerous to draw conclusions from only one experiment, so I tried a second stronger beer
called "La Chouffe". Same results.
I will try the water tomorrow.
Why do you consider those benefits?
I made a polite enquiry in post 82 of this topic asking about the benefits of FFTScan vs RF Scan.
It was you replied in the sarcastic tone comparing drinking beer to water, which did not address my question.
Now that I replied back in the same sarcastic tone it seems you are unable to take it and wish to proceed further down the route of ridicule.
If you cant take it back, dont dish it out in the first place.
deeptho
Europe
Here is my result with tbs6909x (should be similar to 69093x)
Strange indeed. Do these peaks stay at the same frequency if you change the range of the spectrum scan by 20MHz?
If their frequency changes also by 20Mhz then, then it is a driver problem. Otherwise it is probably some interference problem or problem with the card.
I did a spectrum scan shifted up 25MHz, and consequently the spikes also increase by 25Mhz. If it's a driver problem, can you explain that deeptho? I think I'm already updated with the latest drivers.
Still with TBS6522, a satellite scan with less obstructing transponders (27.5W) shows more clearly the spikes or pulses along the spectrum -
New StreamReaderEx BDA Tuner v.1.2.5.158 from 10.06.2023
New SR version with FFTScan, the transponder(s) does not match the spectra for 6902se and 6903x cards.
Also, Blindscan2 is greyed out for these two cards.
deeptho
Europe
The code was made for tbs6504, see for example:
Blindscan on linux with tbs cards
so there may be a difference in the version of the chips or in the firmware
version. Perhaps you can find out in the kernel logs which version it is. Look for a line containing
found a Silicon Labs Si21
It is also possible that something changed in neumodvb over time.
Can you grab a spectrum using the command line blindscan tools?
A command similar to :
~/blindscan/build/src/neumo-blindscan
./neumo-blindscan -c spectrum -U 3 -p 3 --spectrum-method fft --spectral-resolution 100 --lnb-type C -a 1
log finds Silicon Labs si2183 and si2157, successfully attached.
Tried to do a scan with the TBS6522, but fails with voltage problem -
Might be as you suggest, a firmware compatibility issue?
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
first frontend - terrestrial/cable, second - satellite
deeptho
Europe
Obviously, but what is important is the model number. So the other information appearing in the log file lines related to si2183 and av201x
No, you need tospecify the frontend with --frontend
I'm still having problems setting the commands correctly. I seem to be going backwards. It was so much easier when I had only the one tuner to deal with :-doh
-U is 0 (first port in my diseqc switch)
I try -a as 0 or 1, it makes no difference.
frontend 1 (dvb S/S2)
p 3 (H and V)
deeptho
Europe
p 3 (H and V)
You have two dashes missing in the command.
In the mean time I doubkle checked the spectrum of tbs6504, which uses the same code. There are no spurious peaks there.
What you need to is report the lines in the kernel log which show the models of teh si2183 chip and av201x chip
