Sudden loss of signal Freesat
Mickha
North West
Is your satellite menu similar to this?
hoolibaloo
Sky dish with 2 x Edision Picco S2 on 2 TV's in the home
Nottinghamshire
I'm not 100% sure but these are the settings I can find that looks similar.
Mickha
North West
Can you please explain your satellite dish setup?
Do you just have one dish, pointing at Astra 2, 28.2E, with a separate cable going from the LNB to each of your receivers?
hoolibaloo
Nottinghamshire
And this one?
hoolibaloo
Nottinghamshire
Yes that's how it's set up. 2 cables for 2 receiver's. It's a new universal quad LNB on an older sky dish that was up when we moved here - there's never been an issue with reception until this week.
manic01
TM5402 mk1/2/3/4 TM1500 TM Mini various TM Nano various TM600 TM F3/5 TM Twin etc etc TD110
GB
Mickha
North West
Try 11344 vertical 27500
Mickha
North West
Can you try disabling Diseqc 1.0, or is that on by default?
I'm beginning to think that either your dish has moved, or your LNB isn't correct.
Who replaced the LNB, and when?
Do you know the make/model?
hoolibaloo
Nottinghamshire
Disabled the Diseqc 1.0 then rescanned - no change.
We replaced the LNB ourselves 2 days ago I think now and I've included a photo of the make and spec.
manic01
GB
What channels did it find?
hoolibaloo
Nottinghamshire
Strange thing we just noticed. Every time we exit the satellite installation menu after inputting the changes you've said, it changes back to the settings it was on originally? So goes back to Astra 31.5e.
Mickha
North West
When you changed the LNB did you then get a picture?
Did you ensure that the LNB connections were covered by a protective rubber boot, or self amalgamating tape?
We had a lot of heavy rain, last night, where I live, and if water gets into the cable you can lose signal.
90% is a lot of signal quality for a basic sky dish, but different models of receivers, can provide wide variations, in the signal quality display.
I wonder if thee's a factory reset option, so that you can set it up again.
hoolibaloo
Nottinghamshire
It's finding a lot of channels on the upstairs - it'd be easier to say which ones don't have a signal. But none have pictures only sound.
The downstairs TV gets no signal for any channel.
Have you tried unplugging it and plugging it back in or factory resetting it? The screwed up video and it happening to two receivers may suggest a power surge, do they have internal power supplies or separate 12v adapter? If the latter you could try a different one.
Mickha
North West
You can try a factory reset, which will take you back to when you first set it up, but this might not solve the problem:
hoolibaloo
Nottinghamshire
Just tried to factory reset however there is a pin on the setting and I believe this may be because the receiver was designed for the German market as far as I know and the settings have been adapted for the UK - thinking the pin code may be to protect those settings. We imported both receivers from a small retailer in Ireland. I did reach out to them but they are out of the 12 month warranty so they didn't want to help.
manic01
GB
Manual here
hoolibaloo
Nottinghamshire
The TV and receiver were turned off at the socket switch the night it went wrong and also on a surge protect extension. Internal power supplies as far as I know as there's no separate box on the wire.
Mickha
North West
The default pin, in the video, is 0 0 0 0, unless you set a new pin it should be that.
hoolibaloo
Nottinghamshire
The new LNB didn't work from the get go..no rain when it was connected..so not sure really.
