Adapting an astra/hotbird monoblock to a 100 cm dish
rodscha
I d like to get a 100 cm dish instead of my present 78 cms which works fine with a 6° monoblock.
How will the 6°spread ,for78 cms,be affected by this larger 100 cms dish?
Which would be an example of multi sat reception adapted to 100 cms?
7w,5w,9E,13E,16E,19E would me my targets.
Also 26E/28E if feasible.
Rotors won t work,too much wind!
The monobloc spread will be narrower on a bigger dish.
rodscha
Thank you very much,and a happy Easter!
so,instead of 6° for astra/hotbird,how much would it be ?
Lat 43/long 2,33E
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
This would be 6 * 78 / 100 = 4.7 degrees, assuming that the opening angle or f/D ratio equivalent of the two dishes are equal.
A bigger dish will have a smaller beam width, which implies that a bigger dish is less forgiving for mismatches in monoblock distances.
A 100cm dish often allows to use separate LNBs, on a multifeed rail. Is that not an option, for you?
Greetz,
A33
rodscha
yes sure I m considering the idea
May a 4°monoblock work on 13&19?
adjusting for nearness of dish possibly?
a33
XSAT410
Rebox RE-9000
The Netherlands
4°monoblock, 6°monoblock, that is all relative to the width of the dish, and f/D ratio (equivalent). These latter values are often not mentioned.
A 4°monoblock on a 60cm dish would function as a 6°monoblock on a 40 cm dish (with equal f/D-ratio(equivalent)).
So what kind of 4°monoblock do you mean?
And how would you "adjust" something, on a monoblock? Apart from what Lazarus wrote? (The "spread" can easily be made wider, but hardly smaller...)
The crucial factor of a monoblock is the distance between the phase centers of both feedhorns of the monoblock. Or, the same value: the distance between the center of the two 'tubes' of the monoblock.
That distance must match the angular distance between the two satellites from your location, and the effective focal length of your dish. Accounting for Beam Deviation Factor, of course.
Multifeed skew can be calculated; I've a pretty exact calculator nowadays.
Greetz,
A33
rodscha
it seems what I need is adjustable LNBc
Moreover the dish is standing near my sitting room,so I can easily fiddle whenever I feel to try some less usual sat,and retune to basic 9//13/16/19
16 not being a priority.
Or a second dish.
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
My dish is skewed without any calculator
45°E - 42°E - 39°E - 33°E - 28°E - 24°E
p.s.
my brain is capable enough to imagine how to manage, without 5 years studying at university to be an engineer
LeBelge
Belguim
AtOM13
near Marseille
Triax 100 cm, lnb Inverto black Ultra
Laminas 150 cm
Marseille
Yes you can, I used before a 6° monoblock Sedea on my Triax 100cm without problem, you won’t have the same quality with using two lnb separately but it’s ok. Now my setup is Thor/Hotbird/Astra with 3 LNB on my Sedea 80cm
a33
XSAT410
Rebox RE-9000
The Netherlands
And another example:
A triple LNB 19-23-28E, designed/meant for a 60cm dish (triax64) in the Netherlands/Belgium, actually gives better reception on a 70 cm dish (triax78).
Alignment must be done very precisely, though.
Greetz,
A33
rodscha
@ A33 Good morning!
i am 1000kms more south,Carcassonne (100ks from Spain as the crow flies)
,so I won' t be able to do that.
But it looks very interesting indeed!
rodscha
This looks really interesting!
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
