uk bbc channels normally on 28.2 on intelsat 907 27.5w ?
maxi_power
120cm motorised dishes
PT
At certain times of the day I can capture it, but it is impossible to have good continuous reception.
PT 110cm parabolic
anto@
italy
la porzione di banda che va da 10900 a 11200 circa è occupata da 2 tp con una banda di 95 MHz irradiati dallo spot di mare centrale, di conseguenza lo spot di mare nord è coperto da questo spot questo è quello che vedo dall'itlia del nord
the portion of the band that goes from 10900 to approximately 11200 is occupied by 2 tp with a bandwidth of 95 MHz radiated from the central sea spot, consequently the north sea spot is covered by this spot this is what I see from north Italy
Nalleman
Motala Sweden
Sweden
Which makes it impossible to get the North Sea beam in Italy I presume.
robbieb43
London: 1.1m Triax, Stab 100 + 3 fixed 60cm, VU+, Qbox Mini HD, DM800, Echostar HDS600
Canaries: TM 5402, Dm800HD, Qbox Mini HD, DM600, 1.4m, 2 x 1.2M, 1.0m, 0.9m fixed.
London and Canaries (Costa Teguise)
Any luck in Portugal??
I am located in the Canaries and after a survey of the dish it looks like I have my work cut out. After 10 years of salty sea air the Channel Master 2.4 has weathered quite well, but can’t say the same for the LNB: all fixings brittle rust and the connectors all caked in some form of oxide. Even freeing it to take down to the workshop looks like a job in itself:(
robbieb43
PT 110cm parabolic
I guess the footprint of the interfering spot may be more relevant here than the distance from the North Sea spot.
7mdish
Milan, Italy
Yes I confirm. Tested with my CM 2.4m in North part of Italy, near Milan.
Both massive transponders from central beam are booming here, so the BBC one is totally hidden.
I believe that without these "interfering" signals probably it would be possible, as it happens for 28.2 East. But in this situation.... well, no way unfortunately. Very bad luck.
Do you know who uses these 100MHz large transponders? Any chance they will be switched off in the future?
PS: It would be very interesting a reception survey from all forum users having large dishes in all part of Europe. Who is able to get the BBC and in which location outside the UK?
robbieb43
I may be hopelessly confused, but looking at Telstar 12 Frequency Plan that was published by another poster it looks like the Med Central S3 uses the same spectrum that the North Sea S1 uses. Lyngsat does not show any active transponders with overlapping or closely adjacent frequencies, but this seems to be permissible. If it is the S3 beam that is the source of the interference, then perhaps those of us further west may have a chance. Perhaps someone who knows what they are talking about could advise? TIA
Nalleman
Motala Sweden
Sweden
Since I'm getting Freesat from 28 E I have never bothered with 27,5 W and 15 W (except when MSNBC was available at 15 W).
However it would be interesting to know how reception is at various places in Europe as suggested by "7mdish" above.
anto@
italy
I apologize for the translation this morning but the phone played a trick on me
in the photo below you can see the power of the 2 tp that are received in Italy spot Central
which make reception of the BBC mux impossible at my latitude
Not that it helps, but a distorted 70cm dish here is picking up the mux from 15W without trouble.
(A few miles from Heathrow)
rodscha
The ESPN mux? Very strong here too!
is there anything to draw from this,or is it irremediably scrambled?
Since the thread was originally about collecting signals from the UK channels, I was not going to search outside the parameters.
If you have the detail of the interfering transponders I can have a scan here after dinner.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
I'm getting the BBC HD etc and ESPN. Mid Sweden 80cm. Get all the 14W stuff too without moving the dish.
Indeed, the two trps(11012 V and 11137 V) with symbol rates 107141 have long been active and have a strong signal in many parts of Europe.
Butacas
90 cm motorised dish (1 m x 90 cm) + fixed [DiSEqC 3 x 1] {80 cm x 74 cm} Hot Bird 13° E, {65 cm} Astra 19,2° E & {60 cm} Hispasat 30° W + fixed {60 cm} Astra 28,2° E.
Motorised dish currently: 40,5° West to 45° East.
Vu+ Solo SE V2, Vu+ Zero 4K, TBS 5927.
Spain, Galicia (Ourense)
Good signal here on the BBC frequency. Telstar 15º W with 90 cm motorized antenna.
Butacas
PT 110cm parabolic
In the morning and during the day the signal levels (BBC Telstar 15º W frequency) are better than at night. At night the signal levels drop noticeably and it is not until the next day that they recover again and so on.
FC GD
Antenna: SelfSat H50D4
Pay Tv: Allente, Telia
Stockholm
Where are you in mid Sweden? Örebro? Jönköping?
Here in Stockholm i see those 100MHz transponders and a weak glimpse of 11043 V which is unusable.
ESPN on a 65 cm gives me 7,7db and stable picture.. if 80 does the trick i ll upgrade mine to 90cm and give a try.
Nalleman
Motala Sweden
Sweden
He's in Vansbro according to his profile info.
7mdish
Milan, Italy
What is the content of both transponders? Surely data, but what? Internet by satellite maybe?
