Telstar 12 Vantage.
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
As I mentioned in the other thread, better signal (BBC frequency) during the day than at night.
I have a difference of just over 2 db of signal, between the best time of day and at night, which is when the signal levels drop the most.
According to the official beams you have no issues receiving Telstar in orense even with 60cm dish !! May be your motor and dish needs ajusting !?
John H
RCA 12v tv, icecrypt 1600chd, 1m dish, 80cm dishes (2).
Spain
Does anyone have any insights in regard to fringe reception of Telstar 15w Euro Spot 1? Specifically here in the Canaries (29N 13.5W) - we have a number of old 2.4m dishes sitting around from the old Astra 2 chasing days and I wondered if it was worth getting the PlusGas out?
How easy is it to get one of these dishes sent to catalonia and what would the cost be roughly? I've been trying to get a decent size dish for nearly 10 years with no luck whatsoever. Cheers
John H
Spain
pipino
Back from the dead
Signal here in Catalonia is none existent on a 1mtr dish.
I had a positive report from someone in girona with 1.50 prime focus !!! may be thats what you need ?
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Don't know if it is me or the BBC.
I had all the HD channels then yesterday Channel 4 HD quit. Today i'ts back along with BBC ONE HD and 5 select but others are missing. I, of course, have been messing with Lamedb etc.
What are others seeing?
rodscha
2galli at Toutes nos paraboles, toutes dimensions has this kind of stuff. English & French spoken.They are near Agen,North west of Toulouse,not too far from .cat
At least they 'll know where & how to find them!
Discuss with them as whether you can receive BBC where you are,Catalunya is known as a "null" place...so ,check & discuss first!
I would suggest anyone watching for minimum signal wait for a few days until everything has been stabilised (the providers can still play with signal and even the footprint)
That saying there is a 2.4m here, that 2 piece Channel Master in receive only configuration.
It has had just over three years of use here in the UK, the previous owner owned it for seven years but most of that would have been in storage.
£250 collect.
A matching king post would be £100 otherwise a Baird (Colorado) NPMM can be supplied for £220 if taken at the same time.
Butacas
90 cm motorised dish (1 m x 90 cm) + fixed [DiSEqC 3 x 1] {80 cm x 74 cm} Hot Bird 13° E, {65 cm} Astra 19,2° E & {60 cm} Hispasat 30° W + fixed {60 cm} Astra 28,2° E.
Motorised dish currently: 40,5° West to 45° East.
Vu+ Solo SE V2, Vu+ Zero 4K, TBS 5927.
Spain, Galicia (Ourense)
No, the motor and chainring are fine. It also happens to me on Astra 2 that there is a better signal in the morning than at night.
No problem watching it all day long on Telstar.
With 60 cm on a motor it may not be enough, the settings differ compared to a fixed antenna. Improving signal levels on a fixed antenna.
With a fixed 60 cm antenna for the BBC frequency from my location it may be a bit scarce. What they mark in the official coverage traces does not always adjust to reality.
Nothing wrong with the reception of any channel just now (using the GTMedia box)
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Same here 'CH'......all 100% on GTMedia Combo. :Y
I'm not sure about this, but at the moment, trps 12596 V,45000,3/5,8PSK and 12717 V, 24902,3/4,8PSK at 15.0W seem to be used as a kind of backup for the BFBS package on 11221 V,30000,5/6, S2 at 10.0E.
Now, they are using the 6.4 channel on both muxes and doing the end-of-week analysis of the English premiership on BBC Sport.
Butacas
I have a signal on both frequencies. 12597 V with 12.7 db and 12717 with 10.5 db.
The fact is that I see it fairly well (sometimes as if it were pixelating) only for the 12717 V frequency and for the other frequency very bad, in SmartDVB.
I know that it is a continuous transmission and apparently the TBS5927 (maybe not completely compatible) but there is a difference in being able to see it with this TBS tuner between those two frequencies.
maxi_power
120cm motorised dishes
PT
In the morning and during the day the signal levels (BBC Telstar 15º W frequency) are better than at night. At night the signal levels drop noticeably and it is not until the next day that they recover again and so on.
I've had a stable signal for 24 hours straight, day and night, I don't know if it's the weather conditions or there has been some change. If it stays like this, it's not too bad, the signal is low but i can see it.
Butacas
I have better signal levels than a few days ago, they are somewhat higher on the frequency of the BBC 15º W channels.
First paragraph.
Butacas
Yes, I still have that variation, (now it still does not reach 3 db but it is getting closer) from night to day. I don't know why the signal (BBC frequency) becomes so weak at night.
Also through this same satellite I have seen how the signal of the ESPN channels went to zero and apparently it is not the first time.
Nalleman
Motala Sweden
Sweden
I used to watch MSNBC on this satellite and the that signal varied during the day too.
Don't know why but MSNBC left a long time ago so I haven't investigated it further.
iandoh
Pärnu. Estonia/Burgas, Bulgaria
1m Mutlibracket (19e, 13e, 10e, 9e, 4.8e) & 1.2m @ 28e
NBC now deliver MSNBC International via fibre link to providers rather than the unreliable 15W feed that went out whenever the weather was bad in New Jersey.
John H
Spain
Guys, what size dish are you using for this Sat? My 2m dish and icecrypt box pick nothing up.
