Astra 2G: Central & East Europe Reports
Pietclock
125cm
SE Germany 50°N/11°E
current situation:
the 26MHz 2G Europe TPs are very strong... even stronger than what you get at 19.2°E...
npire1
Humax Foxsat with 2.5m prime focus dish & Invacom quad lnb
Prietrzka Slovakia
This morning I moved my dish with my positioner one click left or right and then one click up or down (Not sure which as my dish is too far away and I don't have the cables labelled etc) but I am now getting the c5 transponder on 2g. I have had this before with 2e/2f. If you focus on 2e and get the best signal, 2g is one horizontal & vertical click away. I expect I will lose 2g this morning and will have to click back to focus on 2e later this evening. Anyway It's a good sign ! Hope may not be lost entirely !
otokoc
DM920HD
prodelin1244
Balikesir,Turkey
my channel master 1.80m wiht no signal all astra2g transporters :( Turkey/balikesir
npire1
Prietrzka Slovakia
Getting better ! Now I get c5's bbc 2 hd, cbs drama and a few others from around breakfast to early evening without any dish moving whilst still keeping all the usual channels on 2e. The evenings on 2e are still fading out for the prime time most evenings.
Archive4
I know this will sound daft! But if you moved the dish one bump East during the evening would this help 2E?
npire1
Prietrzka Slovakia
Yes I was doing just that each night but last night I didn't lose 2e so I left it and have again today received the 2g c5's etc so fingers crossed the signal's are improving. For example to start off I only got c5's and cbs drama but today the bbc 2 hd channel and some others were working.
npire1
Prietrzka Slovakia
Also they are both on slightly different elevations so one click up/down also appears to get you a better signal !
Archive4
:-bighappy:-bighappy
Serafeim
5 dishes, Technomate 5402 M3
Arta, GREECE
Arta, Greece with OP 125 pointed @ 23.5E.
Archive4
Sorry, just a little confused. Pics state 28.2 and text states 23.5. If I looked at 23.5 I´d get Astra 3.
I know location makes a difference to where you actually point the dish, but I can´t get my head round this!
Retired Mod
www.timo.me.uk
The LNB is offset and looking at 28.2E, the dish face is looking at 23.5E.
Archive4
Thanks for that, multi LNB set up, but if the LNB is looking at 28.2 ish, isn´t that more relevant than where the dish is pointing? ( Just to help me and other new members )
Retired Mod
www.timo.me.uk
Ah but the fact that the dish is not looking directly at 28.2E means it's not as efficient. The further the LNB is away from the centre the less signal it picks up. So Serafeim is just warning us his 1.25m dish will be under-performing a little.
Archive4
Thank you Master Timo, Grasshopper has learnt some more
Serafeim
Arta, GREECE
Sorry for being confusing.
From left to right: 13°E, 16, 19.2, 23.5 (center), 26, 28.2, 31.5 / 33°E
Archive4
Just sat down with pen and paper. Unfortunately did not have a protractor, but if I´m correct the LNB looking at 28.2 is probably nearer 28.1, thus meaning it should pick up 2G better than 2E. If I´m wrong, send me a new protractor, mirror and a line of " talc "
Tururu
Assembled with recycled parts
Recycled as the owner.
It is to play with the reflected signal at the antenna, an antenna of 80cm each 6º to put a displaced LNB, estimated to be as losing 5cm diameter antenna.
So will your performance gain in dB.
Es jugar con la señal reflejada en la antena, en una antena de 80cm cada 6º al poner un LNB desplazado, calcula que es como perder 5cm de diametro de antena.
Asi sera su rendimiento, ganancia en dB.
An example Astra and Hot Bird satellites are in the same position, but the antenna is focused on one or another satellite.
Un ejemplo con Astra y Hot Bird, los satelites estan en la misma posicion, pero la antena esta centrada a uno o a otro satelite.
An antenna that is well documented in relation to its performance and loss of LNB's displaced is the WaveFrontier T55/T90.
Una antena que esta muy bien documentada en relacion a su rendimiento y las perdidas de los LNB's desplazados es la WaveFrontier T55/T90.
PS:
Serafeim
Arta, GREECE
Reception from Arta, Greece.
