1.2 Metre Max digital or 1.1 Metre triax dish
costas1234
none as yet
london
I am soon moving house and need a plan to buy a decent motorised satellite dish and wanted to get be able to lock feeds and also have a signal for nilesat and/or the fringe signals and east beam. Currently living in Berkshire, SE England.
Also how much would a installer charge for the labour installation only.
Why not got for something proper, like a 1.2m Channel Master with a polar mount? Often come up on eBay for pennies.
Laser
Check site- purplesat He will quote you.
Top job. Did a dish for me.
Would agree. Try for the Channel Master 1.2m
archive10
CM120 is the proper kit. Does not rust or bend, and will perform as you'd wish for.
But it requires a polar mounts (hens teeth or expensive from SSS) and actuators + v-boxes.
Laminas OFC 1200 is light and will fit nicely on a standard (high-end) motor if mounted in a not too-exposed place.
Lower-priced (smaller) steel dishes such as the Triax (beware, they're smaller than you think - the 1.1m Triax is really a 98 cm dish!) are easier to come by, and will fit easier on the motor, but the weight may be the same or higher than the Laminas plastic 1.2m dish - which is indeed a 1.2 meter dish...
Also consider the Gibertini 125 - very nice dish, but also a bit heavy. Will need Gibertini or other "proper" polar mount.
SO, for price: Go for a motor with a low-cost steel dish (alu if possible) such as the maxview. Revel in whatever you can receive, and marvel at the low cost of the equipment.
For performace: Get a CM120 with a polar mount - if, impossibly, you can find one in usable condition for an installer to install - or grab a Laminas with a high-end motor.
The TD110 is not only heavy, but a pig to adjust for elevation.
It does perform well, though.
Manikm909
Small'ish Dish Man
Kent, UK
bit of silicon grease helps on the sliding bracket - but a pain nevertheless, but very GRIPPY which is good come the winds!!!!
