Swap 1.8m Channel Master for 1.5m dish
Chr0nik
TM-9100 Linux receiver / Edision OS mini 4K / TM-2600 M3 motor / 110cm dish (34.5w to 50e) - 100cm dish (51.5e/52e/53e/60e)
Grays, Essex
HI,
Because of the lack of space in the garden, I will need to eventually get rid of my CM 180cm dish. I'd like to swap it with a 1.5m one, ideally a Gibertini (and with a polar mount).
Let me know if interested.
Turn it upside down.
If only I had picked up that free IRTE 1.5m recently offered instead of suggesting it to the photographer :-doh:-doh:-doh
Oh well :(
Chr0nik
Grays, Essex
I see there is more enough of usable space! Lift it up a couple of meters!
That's the plan what I would like to do but the stand is not big enough and thick enough to hold the dish properly, it's 70mm or 80mm thick so at the moment the dish is a bit wobbly and not plumb - I'll be redoing the garden next year so I can play around it then or until somebody is interested in swapping.
A proper groundstand is all that is required, not expensive.
That IRTE one from Pipedream will probably never be used once it makes its way down south........
Chr0nik
Grays, Essex
Should have asked for it but he already gave me a CM 1.2. Hopefully it'll become available.
Then the only cost is transport, the lucky winner - a photographer - is in North London from memory.
Is there any damage to the dish face?
Chr0nik
Grays, Essex
No, it's in pretty good shape. I'll take some pics tomorrow and post them here.
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
I have a 2.4 cm stand, anyone can have if they pick it up
I've still got this one:For Sale - Non penetrating ground mount for satellite dish or antenna - the pole is quite short, but presumably could be extended if a suitable section of "pipe" and a clamp could be found (I don't have those).
No-body (except a time-waster!) wanted it, and so it's been sitting in my garden for over a year - so, again, f.o.c. for collection in W. London.
Chr0nik
Grays, Essex
I've got one of them which is the one that the 1.8m dish is mounted on - pretty good mounts.
@Chr0nik
Do you want mine as well - if so, it's your's to collect.
I can swing by later in the week. What would you like in exchange ?
butchyboy
channel master 1.8m motorised on c band,ku band,1.2 metre prime focus irte dish, 1.85cm offset mabo dish,vu+duo & 42 HD lcd tv
ireland
HI,
hi would you sell the polarmount on it?,as im looking for a polarmount for my cm 1.8m offset dish.
Chr0nik
Grays, Essex
Hi, unfortunately I did not have a polar mount with the 1.8m dish.
OverwatchX
TBS8920/TBS8922/FS-Passion+/Nokia9600s - CM1.2 40E-40W, 1M Prime H-H, 90cm ofset H-H
England
How much would you want for the dish no swap?
