19.2e Analogue Shutdown schedule
Byteman
bytespace.by
Dreambox DM500s @ 36E
//Amstrad SAT 301 (analog) @ 5W
//Echostar SR-90 (analog) @ 19E
//Nokia SAT 8003 S (analog) @ 19E
Belarus, Minsk/Brest
Wow, this is very useful information! Now it will be possible to record all closedowns using only one dish and one receiver! But, I'll use two dishes :) While one channel is closing down, second receiver will be tuned on the "next-to-off" channel... I wonder if it is possible to connect two receivers to one LNB (if both receivers are tuned on transponders with the same polarization of cource ;))
sixx channel working tp 49 now
Pietclock
125cm
SE Germany 50°N/11°E
@Byteman: of course that is possible... just use a two way splitter with DC decoupling (there just two diodes in it).
@solly: SIXX has been on TP49 for some time now. It is considered as a showcase to promote the new channel which is actually meant as a digital "women's channel" only.
Karnuvap
60cms Dish pointing at 19E attached to an analogue receiver - Philips STU3501.
Computer is Samsung Laptop R610.
Caterham UK
Hi there, My wife is Austrian and for ages we have been getting her the German Channels.
I know that it'll all be turned off at the end of April so I would like to ask is it a simple matter of swapping the analogue box for a digital one and if so what is a suitable bare minimum box?
We are looking to get SWR>>BW, WDR, Eurosport (obviously), ZDF, ARD, BR, MDR, HR, Sat-1, RTL, RTL2, Pro7, NDR, N.TV, rbb,Phoenix, Kabel-1,Super-RTL and especially 3Sat and VOX.
Hope someone can help.
Yep, a Digital box (any cheap and cheerful DVB S generic Receiver will do).
You'll probably have to replace the LNB (on the end of the dish arm) for a Universal one: These are cheap as chips and replacement is a simple matter.
Be aware the digital version of Eurosport only carries the German soundtrack.
Karnuvap
Caterham UK
This is brilliant - thanks. The LNB is reasonably new so I should be OK. I am thinking about buying the Philex 28207RF seems a straightforward option.
Will I need to point the dish elsewhere or should it's current direction still be OK?
Karnuvap
Caterham UK
Thanks for the info - this won't be a problem - Austrians speak the German.
Dont touch the dish - just swap the boxes over.
Karnuvap
Caterham UK
Good new - thanks again. I'll report back with how I get on.
chucklebezza
39east and 19e when I want to see F1, using a tm1500ci
surrey
So just so I can get up to speed on this, will there be no Eurosport avialable FTA on 19 east come 30th April 2012?
It's the Analogue broadcast that is ceasing: Digital version will still be available, but no English Language Audio.
any new list tp hd wil be after 1 may 2012 ?
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
hoi,
Transponder 10 – frequentie 11.347 GHz V: ZDF Kultur HD, ZDF Neo HD en ZDF Info HD Transponder 11 – frequentie 11.362 GHz H: ZDF HD, KI.KA HD, 3Sat HD Transponder 19 – frequentie 11.494 GHz H: Das Erste HD, ARTE HD, SWR HD Transponder 25 – frequentie 11.582 GHz H: NDR HD, BR HD en Phoenix HD Transponder 101 – frequentie 12.422 GHz H: WDR HD
Detaillierter Zeitplan für die Beendigung der analogen Satellitenausstrahlung
und Aufschaltung der HD-Programme von ARD und ZDF
Stand: 5. Dezember 2011, Änderungen vorbehalten
29.04.2012 - 30.04.2012
21:00 Uhr Abschaltung Tp.49 (KI.KA) zum Sendeschluss
03:00 Uhr Abschaltung Tp.30 (rbb Fernsehen)
03:01 Uhr Abschaltung Tp.35 (arte)
03:02 Uhr Abschaltung Tp.36 (Phoenix)
03:03 Uhr Abschaltung Tp.39 (WDR Fernsehen)
03:04 Uhr Abschaltung Tp.40 (hr-fernsehen)
03:05 Uhr Abschaltung Tp.41 (BR-alpha)
03:06 Uhr Abschaltung Tp.45 (Bayerisches Fernsehen)
03:07 Uhr Abschaltung Tp.43 (MDR FERNSEHEN)
03:08 Uhr Abschaltung Tp.48 (SWR Fernsehen BW)
03:09 Uhr Abschaltung Tp.61 (SWR Fernsehen RP) durch SES ASTRA
03:10 Uhr Abschaltung Tp.10 (3sat) durch SES ASTRA
03:11 Uhr Abschaltung Tp.33 (ZDF) durch SES ASTRA
03:12 Uhr Abschaltung Tp.25 (NDR Fernsehen)
03:13 Uhr Abschaltung Tp.19 (Das Erste)
Die Aufschaltung des ARD-HD1 und ARD-HD2 in Frankfurt startet am 30. April 2012 um
03:15 Uhr bzw. um 03:30 Uhr. Die HD-Programme selbst werden erst einige Minuten nach
der Aufschaltung des jeweiligen Trägers für den Zuschauer verfügbar sein.
03:15 Uhr
Aufschaltung des Trägers für ARD-HD1 Transponder 19 in Frankfurt (Das Erste HD, arte
HD, SWR BW HD, SWR RP HD)
03:30 Uhr
Aufschaltung des Trägers für ARD-HD2 Transponder 25 in Frankfurt (PHOENIX HD, NDR
FS NDS HD, NDR FS MV HD, NDR FS HH HD, NDR FS SH HD, BR Süd HD, BR Nord HD )
03:58 Uhr
Abschaltung des Trägers für ZDF-HD1 Transponder11 in Frankfurt (Das Erste HD, ZDF HD
und arte HD)
Anschließend erfolgen die Aufschaltungen auf den ZDF-HD1 Transponder 11 und ZDF-HD2
Transponder 10 in Mainz.
04:00 Uhr
Aufschaltung des Trägers für ZDF-HD1 Transponder 11 in Mainz (ZDF HD, zdf_neo HD,
zdf.kultur HD)
04:15 Uhr
Aufschaltung des Trägers für Transponder 10 in Mainz (ZDFinfo HD, 3sat HD, KI.KA HD)
03:00 Uhr bis 05:00 Uhr
Die Aufschaltung des Programms WDR HD mit regionaler Auseinanderschaltung auf den
SES-ASTRA Transpondern 101 und 111 erfolgt nach 03:00 Uhr und wird vor 05:00 Uhr
The Video for EuroSport is fta on 19.2 east The English Audio for EuroSport is fta on 13 east via 11240V 27500 on these pids 2562,
All you need is a 2 Lnb set up for these satellites & a second satellite tuner run through a Hi Fi system the audio is slightly out of sequence but at least this is Free.
thanks for the list but
29 transponder will be down
only 4 transponder will be on german fta hd
will be 25 transponder empty
Heiner
www.analogsat.de
19,2°East / Technisat Technistar S1, Sky Welt HD
Germany
- 2 transponders will be used for FTA HD from January 2014 (11053 for 1 Extra HD, 1 Festival HD, 1 Plus HD; 10891 for MDR HD, hr HD, rbb HD)
- Sky Germany announced that they get a new transponder this year for HD (also offering MTV Live HD from 4th April on, Sky Atlantic HD from May and TNT Serie HD from June)
- some vertical transponders surely will be used by Digital+/Canal+...
sky atlantic hd know transponder and will be use it ?
Heiner
www.analogsat.de
Germany
transponder is not known but rumour has it that Nat Geo HD will change the transponder for Sky Atlantic HD because otherwise many cable customers couldn't (via Kabel Deutschland for example you can only receive 8 Sky HD channels: Sky Cinema HD, Sky Sport HD 1, Sky Sport HD 2, Disney Cinemagic HD, Eurosport HD, History HD, Nat Geo HD, Discovery HD; at Unitymedia, the second-largest provider in Germany you only get Sky Sport HD 1).
Nat Geo HD is also part of many cable packages so that you can watch it twice.
the sky 3g germany will be move to new transonder also ?
