Advice Needed 44E (Astra 1F)
No rain today, so 11292V 15.8dB, 11391H 16.0dB and 12092V 6.8dB.
12098V seems to have a different (more southern) beam: weakest at your location, strongest at Tururu & adonis1' location.
Here, not much change compared to 27 Feb: 11292V 19.5 dB, 11392H 18.0 dB, 12098V: 19.8 dB.
@ AS: the Flysat footprints are for the previous 54.65°E location.
For the current 44.5°E slot reservation position, I wouldn't expect footprints to become public at all!
The Europe beam for Astra 4A gives a better idea of the actual footprint for Astra 1F may be except for transponder 12092V 6.8dB in Southern Finland strange that is is so low there.
swapped over receivers;-
88 x 78 cm mesh dish + TM5402HD M3 with Inverto 0.2 Black Ultra
11291 V 8000 14.4dB Quality
11391 H 8000 13.5dB Quality
12098 V 8000 15dB Quality
12098V is the strongest here atm - about 1dB above the others.
A switch today to other transponders, giving even higher S/N values (between brackets)
11303 H 8000 DVB-S2 QPSK 3/4 ( 23 dB )
11406 V 8000 DVB-S2 QPSK 3/4 ( 22 dB )
12207 V 4000 DVB-S QPSK 3/4 ( 22 dB )
Again, no SID's found.
Kveys
Southern Finland
11303H 20 dB (F 3/5 not show more than 20).
11406V 19.5 dB
and again one "weak" 12207V 11.1 dB.
Cor blimey these are strong!
11303H 17.1dB
11406V 17.4dB
12207V 18.1dB
This is on the fixed 46E dish!
pontiend
Contibruter
south yorkshire
This is what I get on my 100cm.
TBS6925 100cm Dish.
Massive signals off 1F this morning 17dB on 11303H 8000 & 11406V 8000. 18dB on 12207V 4000.
Just the carriers on though :(
(1.1m Triax aimed at 46E!)
No signals on previous transponders as they have moved again:-
11420 H 8000 S2 QPSK 3/4
11313 V 8000 S2 QPSK 3/4
Only 2 found.
  • 1F-footprint-fact-sheet.pdf
The last is 12486 V,8000,3/4,Dvb-S2
12486 V 8000 S2 QPSK 3/4 just found it as well.
New freqs are blasting in here
11420H 8000 15.9 dB
11313V 8000 17.2dB
12486V 8000 14.8dB
On fixed 46E dish.
Just a shame theres no channels on the carriers.
Oi SES!
Just data feeds for GazProm
adonis1
11313V 8000 6.3 db
11420V 8000 16.8
12336H 5520 4.2
12486V 8000 19.0
12486H 8000 5.1
All Astra 1F transponders gone now.
