52E (TurkmenAlem/MonacoSat)
Nowt here in black and white land, either.
Fisty McB
See my signature...
County Tyrone, N. Ireland
12437H coming in fine here (9.4db SNR), as well as 12265H & 12303H (10.3db) as well as the tests on 11261H (9.4db). However not even a sniff of 12226V for whatever reason. :oops:
12437H blasting in here at over 13dB. All tp received with good signal here except the MENA beam one on 12456V (no signal)
Archive4
The MENA beam is the only one I can see, there are a few new ch´s on 12053 H 27500 that I have not picked up before
Jamie A
Very strong signals near London, getting 17.2 dB from 12303 V. Other than Turkmen Sport, there's nowt worth watching.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
I'm still having problems with 12226V. I changed the frequency to 12228V and I am now getting occasional bursts of picture and sound. I am getting 9.2db during bursts. I notice the transponder is in mpeg2 whereas the other transponders just above this one are in mpeg 4.
12226 V 30000 S2 8PSK is the weakest transponder here so maybe the signal is too weak for your current set up ?
88cm dish + SpiderboxHD9900
11262 H 27500 2/3 DVB-S QPSK MPEG-2 = 74% Signal Quality
12226 V 30000 3/4 DVB-S2 8PSK MPEG-2 = 61% --------------
12265 V 27500 2/3 DVB-S2 QPSK MPEG-4= 77%
12303 V 27500 2/3 DVB-S2 QPSK MPEG-4 = 79%
12437 H 30000 2/3 DVB-S2 8PSK MPEG-4=71%
Also a factor to take into account is the FEC @ 3/4 on 12226 V 30000 may be contributing to poor fringe reception.
The signal is playing up here now due to rain & the 3/4 fec.
Working ok here now on 12226 V 30000 now it has stopped raining.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
Normally 5db will get me a picture but on 7 East I really need 6db due to the fec used. 9db is more than ample signal for my system. I wonder of it is extra noise being introduced so low to the horizon. I have actually changed my Invercom for an Inverto quad (quad has shorter drop for clearing Fibo arm) and, although it has had a positive impact on signals generally it fails on this one. Incedently, I am now able to get the Russian channels on 62 East now. Only one radio channel in the clear now but a good 10 dB rather than 6db before changing the lnb.You win some you loose some :)
Archive4
Are you picking up the ones on Yahsat by any chance (MENA beam - zip here.)
Yes , you are correct, they are Yahsat ( 16 dB ) do have one on 11261 H 27500 at 6.3 dB, so that´s from another bird as well, will look after tea!
Fisty McB
See my signature...
Changing it to 11228V made no difference for me. I suspect the transponder is not at full power along with a higher SNR required due to the use of 8PSK & 3/4 FEC, and as mentioned in your next post the location near the horizon might be a problem - TurkmenAlem has an elevation of only 8.5 degrees from where I am and is just visible above some trees.
Tururu
Assembled with recycled parts
Recycled as the owner.
Changing it to 11228V made no difference for me........................
It is not right with the beam west 100% /no es correcto con el haz Oeste 100%.
Madrid 90cm.
11262 H 27500 2/3 DVB-S QPSK MPEG-2 = 10.5dB SNR 65% AGC 99% BER 0 (Rover-SRM50 C/N 9.3dB.)
12226 V 30000 3/4 DVB-S2 8PSK MPEG-2 = .............................(Rover SRM50 C/N 4.0dB.)
12264 V 27500 2/3 DVB-S2 QPSK MPEG-4 = 5.50dB SNR 31% AGC 99% BER 0 (Rover-SRM50 C/N 5.7dB.)
12303 V 27500 2/3 DVB-S2 QPSK MPEG-4 = 5.50dB SNR 31% AGC 99% BER 0 (Rover-SRM50 C/N 5.2dB.)
12437 H 30000 2/3 DVB-S2 8PSK MPEG-4 = .............................(Rover SRM50 C/N 3.2dB.)
12456 V 27500 2/3 DVB-S2/8PSK MPEG-4 = 14.0dB SNR 87% AGC 99% BER 0 (Rover-SRM50 C/N 11.3dB.)
Has 11262H been switched off? Im not getting anything here at all now on this frequency.
Laser
Nothing here either. Was watching the 3 new added channels earlier ....
adonis1
