52E (TurkmenAlem/MonacoSat)
Strange that you only had about 3 dB difference, while here 7 dB.
12264 V back to usual dB value and healthy constellation.
Edit: 12303 V 26400 DVB-S2 QPSK 3/4 also back to normal strength, almost 19 dB.
William-1 why posting wrong SR ? Please blindscan!
The signals are so strong here now you could probably get it on a 45cm mini dish.
The switch to DVB-S2 is good, 1.5 dB more margin and 5% higher bitrate.
No need to be compatible with SD receivers anyway, with all these HD channels!
Fisty McB
See my signature...
County Tyrone, N. Ireland
Just did a blind scan, my receiver is now reporting the transmission details as above, except that the modulation is 8psk.
Fisty McB
See my signature...
Fisty, I wasn't around when you posted, but now it's QPSK again!
Tururu
Assembled with recycled parts
Recycled as the owner.
I am not even going to try since I know I'll get it. ....and I am out of satellite positions on the F15 .. grr!
The tank is fine, SAT1 fireplace and the sound of the logs to burn ..... record a CD with 30 minutes.
Working since 1990 in multiscreen, could work and enjoy the evening (I sleep little).
La pecera esta bien, la chimenea de SAT1 y el sonido de los troncos al arden.....grabe un CD con 30 minutos.
Al trabajar desde 1990 en multipantalla, podia trabajar y disfrutar por la noche (duermo poco).
PS:
Fisty McB
See my signature...
Could be my receiver, on a blind scan it's reporting 8PSK but doing a manual scan with QPSK instead it still tunes in OK.
Definitely QPSK ever since the transmission started the only parameter that has changed is the modulation from DVB-S to DVB-S2 so it looks like your Vu is giving you false readings on the Blind Scan.
Tururu
Our tuners are easily fooled as we can see.:-rofl2
VU + DUO2 and DreamBox800S-HD
Nuestros sintonizadores se dejan engañar facilmente como podemos ver.
En VU+DUO2 y DreamBox800S-HD
DVB-S
DVB-S2 QPSK
DVB-S2 8PSK
Note/Nota:
VU + DUO2 the BER (error number always 0) is not working.
En VU+DUO2 no funciona el BER (numero de errores siempre 0).
PD:
Yes I have a similar fault with the SpiderboxHD9000 shows the transponder active on QPSK & 8PSK only the DVB-S2 to S seems to work Blind Scan chooses 8PSK :eek: much the same with a lot of these mass produced receivers with the fec display being non functional as well:-rofl2
4th symbol rate change & 2nd fec change in 48 hours @ 52 east :eek:
12264 V 27500 2/3 S2 HD MPEG-4
12303 V 27500 2/3 S2 HD MPEG-4
Confirmed. :) Pilot is off this time.
Note that Miras is relaying Perviy Kanal now.
Crappy white 55 cm dish still deliveres 13 dB's!
Both transponders down here no signals at all looks like someone has pressed a button in the wrong place again :eek:
12303V gradually coming back.
Please ignore the satellite position this is on my 100cm set up just getting the signal over the rooftop,
90 cm set up is the same no signals from 52 east & this has a clear view of the satellite through to 54 east.
All back this morning with test cards.
Normal tv resumed on the 2 active transponders.
Ive split the reception reports off the launch thread - they are more useful here in the fringe section.
English news noted on channel "Turkmenisten" at around 2115 uk time :)
