90cm Dish already installed and working, alignment with USALS setup
tdwuk
VU+ Duo
90cm Dish
Dark Motor
Quad LNB (single feed)
London
I have a 90cm dish already installed on a side wall accessible from a flat roof. The dish was set up without USALS and I want to get it working properly with USALS and my new VU+ box.
NW London.
Is the motor USALs compatible ?
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Since it is a darkmotor,it should be usals compatible.
tdwuk
VU+ Duo
90cm Dish
Dark Motor
London
I assume it is compatible, when I set my box to USALS it does move the motor to the satellite.
Robbo
Retired Mod
Gravesend,Kent,UK
If it moves the dish to the satellite using USALS, what's the problem?
tdwuk
VU+ Duo
90cm Dish
Dark Motor
London
It was not aligned correctly first time and I have been manually looking for satellites as the installed did.
Robbo
Retired Mod
Gravesend,Kent,UK
But can you get the required satellites by manual tuning?
You can adjust the positions by putting in different Longitude numbers and then referencing to zero (unless the motor requires a manual reset)
