ABS 75 e
gunchik
FERGUSSON
Hi there can somebody give my ancer on my question ,what size satellite dish do i need,im go allready 1.2m dish and 0.3db LNB to receive ABS 75e in london ? im can find any information in forums
soo can us help my please
--T H A N K S--:confused
Hakon
My setup
Laminas180cm P.M 60e-30w
24" SuperJack,Clark-Tech V-Box
Laminas120cm CM P.M 75e-30w
18" Superjack, Clark-Tech V-Box
Gibertini XP premium 100cm
Polar Mount, 12" Superjack
75e-30w
2 x Vu+ Duo
Sweden south
No problem with the north lobe Ku-band in the south sweden(the red cross)
Laminas 120cm, Inverto Black Ultra Single LNB.
gunchik
FERGUSSON
im change my lnb to 0.1 db but still no signal in notrh london ,maybe im doing something wrong?
Hakon
My setup
75e-30w
2 x Vu+ Duo
Sweden south
And the elevation on the dish is correct ?
The elevation above the horizon is going to be about 2 degrees in London , so forget it.
I asked that question not long ago. Basically, it's only really possible if you're on the south eastern shores (think Dover's White Cliffs), where there's NOTHING obstructing the satellite. In Brighton, the elevation is 0.8 degrees. Tricky, but possible.
What are you looking to get on that satellite? For Russian channels, you're better off with getting Platforma on 9e. Available with a 60cm dish anywhere in UK and a cheap subscription (if bought in Russia - 900 roubles or £20 per year for non-HD channels).
aceb
Prof Tuner 7301 /
Sussex
As you say, tricky but possible from Brighton, this how it looked a few years ago just east of Brighton.
Lovely pictures. Very extreme! Any other ones? :) Signal strength, channel scans/screenshots etc.?
