Adult Channels Quality on Hot Bird
beezeruk
Vantage7100HD
Yorks
Thanks analoguesat, I understand that, but the curious thing is, that the Horizontal signal only disappears during the day. Changing the LNB has made no difference. As soon as the light starts to fade back comes the signal as strong as ever.
Curious isn't it ?
RedDwarf
Sky Minidish and Sky Digibox signal now detected
Core 2 Q9450 up to 3.5GHz
Gigabyte GA-X48-DS5 motherboard
4GB DDR2
Gigabyte 3850 Gfx card
Mystique Dual DVB-S2 PCI-e
Pinnacle Dual DVB-T Pro PCI
Central Midlands, UK
Just checking this thread.....for a friend you understand ;)
I would like to make a suggestion regarding the table for easier comparison. If a bits per pixel were posted then it would be easier to compare them as they do use different resolutions and frame rates which can make a big difference in quality.
bitrate [in bits per second 2300 would be 2300000 / total pixels 1x resolution X y resolution] X frame rate [half interlaced field rate]
Example, in theory the Redlight channel should provide slightly higher video quality by just comparing the numbers but the resolution is lower so if it was resized onto a HD TV the video could be less sharp.
Polsat Playboy TV UK	1500	544x576	    0.191
Redlight Redlight Mixx	1400	480x576	    0.203
presuming these are all 50i broadcasts
RedDwarf
4GB DDR2
jack10
like computers tech
oman
i think there is no good s_x channels on hotbird /all channels with bad quality/mybe privet spice its good with resaloution not type of movie/but i think the best channels now is penthouse hd hd1 hd2
and the bad channels is sexview
SCORPION58
SKY+ & DELL DIMENSION
9150 COMPUTER
WALES, UK
Hi, thanks for this list, extremely useful information.
Regards :- scorpion58
moza
I have a sky digital dish and virgin media
keighley
Hi, I am new and know very little about satellites. I currently have sky digital and virgin media in my house. Is there a way i can watch adult channels free on them.
Secondly how do i get, or what would do need to do to get the adult spice extreme or something.
please advice.
regards
moza
moza
keighley
How do i get or subscribe to Private Spice channels.
thanks
thegilston
dreamcast 7020
motorised dish
leicester boy
any sat shop will be selling the veiwing cards.. just het fixed dish, and cheap box and your on the way.. no hassle
deldadeh
starcom sr-c6
Iran
isn't there any free adult channel on hotbird?
No there isnt. Please fill your location in correctly "on my desktop" isnt any help whatsoever when folk are trying to help you with technical questions.
deldadeh
starcom sr-c6
Iran
i cant change it!
Iran!
sorted - admin :D
zomex1
8 feet dish, echolink 777 receiver.
karachi
i have a 8 feet dish, echolink receiver (777), a dongle which decrypts all encrypted channels. but am unfortunate not to receive all the channels (adult/ non adult) on hot bird. i fail to understand why i can view some channels without any interruptions on hot bird and cant view others. are there any ways in which i can increase signal quality?????
Of course there is - put a bigger dish up :D
There are 3 different satellites broadcasting at 13E - Hotbirds 6 8 & 9. You are probably picking up the channels on Hottie 6 which has the widest coverage area over subscontinental India.
Zorba
3m(28.2E),1.5m(19.2E.13E,10E),1m (4W ,7W)1m (?).diseqc 10,sky plus,VU+,telergy iptv.
Satlook nit colour + Horizon hdsm.
Limassol, Sunny Cyprus
Tell us more about this dongle :-)
Quite common in the Middle East Zorba - basically its a commercial card share type system via satellite - and as such discussion is absolutely forbidden here.
zomex1
karachi
analoguesat's thanks for ur reply.
i am able to scan private spice, but it wont show any pictures. the signal intensity is around 78% but the quality is just 28%. what to do, would getting a new receiver solve the problem
Ive alreday told you what the answer is in post #69.
BTW why have you filled YOUR profile in with MY system details?? I'll change that if you dont mind - its fairly unlikely you have access to Sky UK.......
It might seem like a small point but having your profile filled in correctly is vital when we are trying to sort out technical questions.
rishabh200
reliance big tv
india
Dear
pls tell me how to view adult tv channels in india in big tv
regards
rishabh200 said:
Dear
regards
You cant - Adult channels are forbidden by your government in case they morally corrupt your people :D
You woulsd need extra equipment and a very big dish at vast expense. To be honest its far easier & cheaper to find mature content on the internet ;)
This one has been going over 3 years so time for this one to close I think.
