Al Jazeera Sports HD 5 picture problem
buckshee
Eutelsat 7 West A
12476.00
V
E40
MENA
DVB-S2
8PSK
27500 2/3
Al Jazeera Sports HD 6
Al Jazeera Sports News HD
NBA TV
Fox Sports
Very poor picture quality (breaking up). This frequency only.
trigger
Puerto del Carmen, Lanzarote
30W, 27.5W, 7W, 0.1W
4.8E, 9E, 13E, 19E, 23.5E, 26E, 28E
Technomate 5402HD super
Bein Sports on 25.5E
FTE Mini S2T HD Analyser
Horizon HD S2 sat meter
Lanzarote, Canary Islands
Because this is on Eutelsat 7 with a much smaller footprint than Nilesat. Check your dish to get the best out of it - try a better LNB - or a bigger dish.
buckshee
Thanks Trigger, but I have overkill on the dish 1.35M and a 0.1 db lnb Signal strength and quality are 100+% Cleaned card and changed LNB.
Abu dhabi Sports and all other al Jazeera sports HD1 - HD5 excellent. Only the 12476.00 frequency a problem. dropped an e-mail to Al Jazeera to see if they are having teething problems.
12475 is close to the dect interference problem frequency especially noted around 12480.
Any wayward L-band transmissions from new dect equipment?
12480 MHz (Nominal) is a prime DECT Phone target >> DECT uses around 1880 MHz.
The TP at 12476 downshifts by 10600 to an L Band (On the cable from LNB to Receiver) frequency of 1876 MHz ........................ So check your cabling for integrity ie Damage, Kinks, Joints (especially Wallplates) and relocate any DECT phone Base/Handsets.
buckshee
Analoguesat - I have a DECT phone next to the satellite box. Could this cause a problem. Shifting it right now.
It's the proximity to cable/connections that's important: The box itself is a Faraday Cage and is virtually bulletproof.
Emissions from DECT kit (etc.) exploit weaknesses in screening (ie Lack of Immunity).
buckshee
Thanks guys, problem solved.
I wonder how long it will be, before someone notices the phone missing :-rofl2 Its never for me anyway!!!
Excellent - another satisfied customer :)
Thats a known bad frequency - I wonder if its been chosen deliberately ? :D
As the power decreases with the square of the distance, even moving it 2 or 3 metres often causes the interference to drop sufficiently to eradicate the problem
