Arabsat BADR-8
marcouk
Vu+ Uno 4K SE, 1.2M Laminas motorised dish. Primesat 1.3 m dish
Hull UK
welcome news indeed.
I am now starting to receive channels that where just outside of my lock up level Alkass 1 to 4 @ 12.245 V for example are now coming in at 9.0 db despite it been raining with quite strong winds. the Kuwaiti mux @ 12.523 H has shot up from 10.2 DB to 13.3 DB and Bahrain INT @ 12.226 H has gone from 6.0 DB to 9.9 DB.
I have noticed that in order to receive some of the weaker channels you have to move your dish a couple of notches which in turn weakens (and in some cases loses) some of the others channels. it may be necessary for us to have two positions stored on our systems from now on for 26East
I think the very large dishes that some of you are using 120cm to 300cm give a distorted view of the actual signal strengths that I am receiving in the South East of the UK with my 100cm dish,
When I receive more transponders from Badr-8 with my 88cm mesh dish it will give a clearer picture of what is available from 26 east.
Flysat said frequency 12054 V still on Badr 4 but is not correct !
Frequency 12054 V hase moved to Badr 8 and signal is very increased !
Flysat follow - they don't lead .......
As of last evening, I got 85 FTA TV from 26E, having historically only being able to get one TP.
80cm dish in North Yorkshire UK, iBravebox.
Haven't checked since, as not currently at home.
88cm Raven Mesh Dish + Inverto Black Ultra Twin
Reception of 26°E (102 x FTA TV & test cards)
S/R 27500 except where stated ( )
11996 H 52% SQ
12053 V 44%
12225 H 22%
12522 H 56%
12522 V 22%
12562 V 59%
12642 H 52%
12682 V 52%
12737 H 64% (7400)
SatSearcher
West Yorkshire
Can anyone confirm that 12149H has definitely moved over to BADR 8? I always struggled with this one from BADR 4, and still get exactly the same signal now (around 8-8.5db, which is just under lock. Seems strange as I've had big improvements on all other frequencies that have moved over.
12149 H 27500 @ 26 east = 66% SQ Slightly higher signal @ 25.5 east = 69% SQ 100 cm set up.
This works on a few transponders from 26 east, BBC News works better here @ 26.3 east
As for your original question has 12149 moved to Badr-8 we will get a better idea when Badr-4 is empty & moves from this position.
according to Lyngsat Badr-4 has move all transponders to Badr-8.
The key to full change over is transponder 12182 H 16200 this is supposed to change to S/R 27500 with a new frequency.
All will become clear very soon. :)
The key to full change over is transponder 12182 H 16200 this is supposed to change to S/R 27500 & modified frequency.
I didn't keep track of the transponders that were moved to BADR-8. The only way to see the change at 26.0E is to scan the satellite and compare two periods.
I found no change in the signal level on BADR-8 in my area today compared to 29.11 #260
AhmadIraqi
StarSat , 90cm, Inverto
Iraq
Dubai channels mux will make changes to its current frequency on Badr-4 (12130, Vertical, 27500 | 3/4 | DVB-S/QPSK)
It will become as follows, if moves to Badr-8:
Freq: 12310
Pol: V
FEC: 3/4
SR: 30000
Mode: DVB-S2/8PSK
22​
QusaiSatIraq
AhmedIraqi
28.09.2023​
12130 V
DVB-S/QPSK​
27500 3/4​
702-508​
Dubai TVMPEG-2220111011201 Ara
Dubai Sports 3MPEG-2220211021202 Ara
Dubai OneMPEG-2220311031203 Ara
Sama DubaiMPEG-2220411041204 Ara
Dubai Sports 2MPEG-2220611061206 Ara
1207 Ara
Dubai Racing 3MPEG-2220911091209 Ara
Dubai Racing 2MPEG-2221011101210 Ara
1212 Ara
Dubai Sports 1MPEG-2221211121220 Ara
1221 Eng
-R- Noor Dubai Radio22131213 Ara
satelliclub
Eutelsat 5 West B + Eutelsat 9B
Tunisia
11804 H is off
and
11938 V + 11958 H + 11977 V + 12523 H + 12523 V + 12643 H moved to Badr 8
satelliclub
Tunisia
Now all this frequency's is now on Badr 8:
11747 V MENA
11785 V MENA
11804 H EMENA (Actually turned off)
11862 V MENA
11881 H CENTRAL ASIA
11900 V CENTRAL ASIA
11919 H EMENA
11938 V MENA
11958 H MENA
11977 V MENA
11996 H EMENA
12054 V EMENA
12073 H EMENA
12149 H EMENA
12169 V EMENA
12226 H EMENA
12245 V EMENA
12265 H CENTRAL ASIA
12284 V NW AFRICA
12284 V CENTRAL ASIA
12303 H NW AFRICA
12303 H CENTRAL ASIA
12322 V CENTRAL ASIA
12360 V MENA
12380 H MENA
12399 V EMENA
12418 H MENA
12437 V MENA
12455 H MENA
12476 V MENA
12523 H MENA
12523 V MENA
12563 V EMENA
12643 H EMENA
12683 V EMENA
and
4 frequency's is still on Badr 4:
12092 V + 12111 H + 12130 V + 12182 H
