Astra 28e received in Yemen
Yes, that's right.
For the recent launches, Analoguesat has expended a lot of effort into collating reports (successful or otherwise) from around Europe and beyond.
Sadly, it seems no such Maps exist for the older 28E craft.
Europesat
strong
Yemen
hi guys
could you please recommend me a powerful lnbf for my 240cm dish
thanks in advance
What LNB are you using at the moment?
Europesat
strong
Yemen
now I'm using star gold fuji
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I have several GI-209P and happy about their performance. Unfortunately there are only Single available. If you get one of those, can happen it works better then that you have. It costs starting from 4 EUR.
Retired Mod
www.timo.me.uk
I use an Invacom QDF-301 quad LNB on a 1.8m dish for Astra 2 and it works well for me. Apparently the single and twin output versions of the LNB do not perform as well but I haven't tested them myself. The problem is it is quiet an expensive LNB and you need a feed horn to go with it (my dish came with its own fitted matching feed horn so this was ideal for me).
Europesat
strong
Yemen
mr. RimaNTSS
thank you for your recommendation
Europesat
strong
Yemen
mr. Timo
Europesat
strong
Yemen
i don't think that kind of lnbs r available here in Sanaa
but I'll try to find them through satellite equipment shops online
best regards
Europesat
strong
Yemen
mr. Timo why r u using such a big dish 180cm for Astra 2 in UK ?
is it requires that big of dish, there?
Retired Mod
www.timo.me.uk
No, the 1.8m is in Helsinki, Finland. But I do not get any UK beam channels and some of Astra 2F Europe beam channels are very weak most of the time. I get good reception of Astra 2A, Astra 2E Europe beam and Eutelsat 28A.
In the UK a 45cm dish is big enough for everything!
Europesat
strong
Yemen
ok, i c
u r frm Finland.
so you're guys form different countries
that sounds great
ok, i c
u r frm Finland.
that sounds great
It's fair to say most of our Members are from Europe, but we also have Members from the USA, Canada, Australia, Africa India etc. etc .
And now your good self, of course!
Thanks to Timo's new siggy, I have to scroll even more now ... :-deadhorse
Europesat
strong
Yemen
wow! that's great
when i joined here i thought only UK members in this forum
am very happy to join here
We're very glad to have you - tell your friends to join us, too! :D
Perhaps he might consider doing the same as us, now that you've mentioned it ;)
