Ax HD 61 Tuner Problem with multistream
4Himdj
1.2 Laminas Dish
Rome
Hello
I have problem with Tuner Silabs I guess is the same of other twin enigma 2 multistream ready receiver
If I use TUNER A I have problem with french multistream on 5W (no signal) and 51,5east FTA Czech's CT channels (glitches and freezing) but RAI multistream channels works great
If I use TUNER B I have issues and freezing with RAI's but I can watch normally french multistream
I have openatv 6,4
any guess?
thank you
best regards
6.4 is an old image. You should update. Or switch to another image, e.g. OpenViX. That way you will you will be able to see if your problem is caused by the image you are running, or if the hardware is broken.
Also try switching the aerial leads to the opposite tuners and see if the problem remains the same.
EnoSat
enosat.euweb.cz
Slovakia
problem with the drivers, the manufacturer does not update them
