Best HH motors for dishes up to 1,2mt
Paolo71
Gibertini 100cm, STAB HH120, Inverto BU 0.2dB, Laminas 120, Moteck SG2100A, Inverto Premium 0.2dB.
TBS 5925, Edision OsMio 4K plus, AZbox Premium HD+, pc AMD FX8350 ram 32Gb. IQMonitor Pro, EBS Pro, Crazyscan, DvbDream, VLC and PotPlayer.
Monterotondo (Rome), Italy
Hi all,
I'm looking for a new HH motor (I already have a STAB HH120 for my 1mt dish) as I would like to build another motorized equipment. For logistic problems on my balcony I could use up to a 1,2mt dish, if my neighbours don't bother me so much. Maybe I'm going to purchase a Laminas 110 or 120. Anyway I prefer to use at the moment an HH motor like STAB, but this company since 2019 stopped producing their HH motors !! So I' m looking for a shop in Italy or abroad who can sell me another HH120 or something like that.
Can anyone suggest me another strong and long life motor like the STAB ? For sure with metal gears, so more reliable for the use and the wind. There are some models like PremiumX or SG2100 or something else, but I accept help from those who can suggest me something very good !
Thank you so much in advance
Paolo
Apart from one rotor design , their production stopped over a decade ago
STAB srl. are/were one of the few motor manufacturers where the dish is bolted above the gearbox. Are you sure you have enough ground clearance with the - elephant's dongle - style as a direct replacement ?
Paolo71
Hi, yes they were. Now I don't know which is the best replacement for a new system (I still have the Stab HH120 with the first equipment, still perfect after about 12 years). From my balcony I can reach for sure 80°East or a bit more (tested with a dish manually), while on the other side I could reach about 45°W or more. I need to know who has different HH motors just to understand which is the best one (obviously I'm going to buy a full metal gear motor, not chinese plastics).
Chinese or Taiwanese ? Regardless you will be getting a metal geared model from somewhere East.
I keep a number of Moteck clones ('Dark' motor) back for the rainy days, tested and ready to go.
Paolo71
Are you suggesting me any good motor ? My reference is the STAB, but in this moment I don't know any other good model and reliable for ever.
Stab HH120 & Dark Motor all metal gears are the best 2 DiSEqC motors for 125cm dish like the Gibertini with the main Dish in aliminum the bracket is steel.
Moteck, though I wonder why do you believe metal gears are better.
Is your location near the sea, in the clouds or underwater ?
Paolo71
Metal gears are stronger. My house is in a quite windy position. PLastics under the sun and hot temperature are weak.
OK, nylon is not for you.
