big problem with my new dm 500 hd
mouhdz
DREAMBOX 500 HD
ALGERIA
2 DAYS AGO I BOUGHT THE NEW DREAMBOX 500 HD WHEN I TIRED TO USE IT NORMALY THE green led only ARE ON.THe 500 HD does not want to start at all. Dreamup dowloades loader and nothing more, no flash menu activates. No IP at all, router does not see any 500hd. Fan is off, Some red leds inside are on.
PLEASE HELP ME
As its brand new get onto your supplier and register a complaint.
mouhdz
DREAMBOX 500 HD
ALGERIA
i live in algeria but i bought in germany , so im asking if there's any other solution to boot it !!!
nenito2k
Core 2 Duo, Echostar 2200ci
North Africa
saha moh ! i also live in Algeria...the thing is that i read that some DM500HD were having the same problem....in belgium, france and UK....it seems the units are defective.
For the moment there is no solution if you live outside europe...that is why i did not want to buy one from there.....
another solution is to post this message on the officiel DMM forum....you will get an answer!
shumifan50
2xDM7025(DVB-S tuner), DM600SPVR, DM800S, DM500S HD, Triax 90cm with MultiBracket 4 sats.
Europe
DreamMultimedia provide very good support. Contact them through their website and they will most likely allow you to return the unit for replacement. Have you followed the instructions carefully for flashing using the mini-USB socket AND ALSO HAD THE NETWORK connected - you cannot flash using only the miniUSB socket, it does NOT work. Look at the post about 'what you should know about flashing your DM500HD.
laziotunisia
azbox hd
ibm x61
tunisia
hi
dreambox support
_http://www.dream-multimedia-tv.de/support
i have green led problem ,dream support request to send dreambox in germany for repair
powel000
Paraclipse 2.40m solid dish,
Jonsa 1.80m dish,
3.40m mesh dish,
dreambox7020SI,
relook400S,
HUMAX, dream 500hd
90CM DISH,
AMMAN-JORDAN
LazioTunisia, please answer me this question Did u resolve ur green light issue by reinstalling your software or did u have to replace ur 500hd.
Jere
I think I found solution.
1. Connect only USB to DM500HD
2. start Dream UP 1.3.5.5
3. start connection
4. connect power
5. when you see that connection is started then connect network cable
6. then you can choose flashing
So I solved problem with green light with out any connection possibility.
I could DM but it have nothing whit my knowledge - it was light from sky!!!!!!!
Hope you going to solvee your problem to!!
Jere
lamja
DM 500 HD ferrari
Macedonia
I have the same problem on my new DM 500 HD after 1 day work, stoped my cooler and not booting, i tryed to hold power button but i cant enter to IP mode where i can flash it, i dont know whats the problem what shoud i do next please anyone help me?
This is what happens if you buy a clone.
