MarkW
- Jan 28, 2014
- Age
- 64
- 1.2 Galaxy,IBU single,Technomate 5402M3
- Jesi,Italy
Yes,intermittents and be soul destroying.You think it's fixed then after a while it comes back!I think you mentioned checking thermistors on the pipes but there should also be temperature cut outs attached to the boiller body.These should be sort circuit.On the combi I had,one was intermittently o.c .I can't see these on the flow chart though.They are normally about 1cm in diameter with a tiny cut-out button in the middle attached to a screw mount.But maybe this is what you meant by thermistor.Lets hope you've fixed it.
