bush BFSAT01SD help in pakistan
ikram92
Asiasat 7
pakistan
Hi i want to help what is the postcode for bush receiver in pakistan
Thats a UK freesat receiver. You cant enter a postcode as you are outside the coverage area of the transponder carrying the postcode information. Therefore the receiver can never set itself up.
Its basically useless in Pakistan.
ikram92
Asiasat 7
pakistan
there i have saw some people used it how i got its software
What were they doing with it? What satellite and/or programme was it showing?
If they were using it in non-Freesat mode then a postcode is unnecessary.
You may be able to use it in none freesat mode but there are any number of receivers that are going to be easier to use rather than faffing around trying to get it going.
