a33
Specialised Contributor
- Sep 24, 2009
- Age
- 63
XSAT410
Rebox RE-9000
- The Netherlands
Now I've got to figure out what LNB and Feed is useable with it. I'm thinking a standard inexpensive LNBF may have too wide of angle.
Looking at the horizontal characteristics of the dish, for an offset dish 1340 * 1268 * 95, the opening angle of that dish dimension would be 64 degrees, so 4 degrees more than in the vertical plane.
So it might indeed be an issue. Not my expertise, though. But when using a normal Ku-LNBf, I gave an aiming advise, to test to aim lower than 'normal'.
@RimaNTSS has an Equatorial dish, which I believe has an opening angle ~49 degrees.
It would be interesting to know what kind of feedhorn/LNB he is using with it?
(Same dish is in use with the blog owner of ftapinamar, Calcular la distancia al segundo LNB (6) )
Greetz,
A33
