Classic films in english on arte hd
4wd
Getting the picture
5 W, 9-13-19-28 E
Arte is great, in so many areas.
Runaway Train is one of those films I continue to watch if flicked past on a channel hop, the cinematography is amazing.
Roughly based on a screenplay by legendary Akira Kurosawa, probably Voight's best outing (Deliverance was Reynolds film)
Now in glorious small screen for not a lot.
It is a shame that some films with English soundtracks on the original film are not always available with this audio on ARTE just the German & French audio despite 4 stereo audio tracks being available on the 3 HD versions 19.2E,13E & 5W + SD version on 19.2E,
Sometimes they do broadcast the English soundtrack if they feel like it :rolleyes:
Data123
Golden Interstar Alpha X
65cm
leeds
Arte are showing classic films over Christmas, I think all have the original sound in English on 13e
18 Dec 2020
Sabrina 1954
Grease 1978
20 Dec
Ben-Hur 1959
21 Dec
Man Without a Star 1955
22 Dec
Great Expectations 1998
25 Dec
Circus World 1964
28 Dec
Bend of the River 1952
29 Dec
It's a Wonderful Life 1946
The Great Escape 1963
30 Dec
Young Sherlock Holmes 1985
3 Jan
Pride and Prejudice 2005
See Programme TV aujourd'hui. Emission, série, film, documentaire for times
rodscha
Make sure you watch the Hotbird version of Arte,to access an English soundtrack!
the astra 1 version gives only French or German soundtrack,sometimes only German...ideal for Sissi!
Strange that on German channels(all astra 1 German channels),generally,very little stuff is available in English,despite the good level in English of most German people!
Data123
65cm
leeds
20 Dec
M (remake 1951)
An Affair to Remember (Cary Grant)
21 Dec
Doctor Zhivago directed by David Lean
22 Dec
The Dead director by John Huston
Great Expectations directed by David Lean
23 Dec
26 Dec
The Ten Commandments
27 Dec
The Barefoot Contessa (Humphrey Bogart)
28 Dec
29 Dec
Suspicion directed by Alfred Hitchcock
30 Dec
The Misfits
The Poseidon Adventure
The Great Dictator (Charlie Chaplin)
1 Jan
And Now for Something Completely Different (Monty Python)
3 Jan
7 Jan
See Programme TV aujourd'hui. Emission, série, film, documentaire | ARTE for times
Rutep
Hotbird 13 east
Iceland
I have been using the timer of the receiver to record some English films on Arte. I have the Amiko Alien 2 audio on "qaa" rather than "qad". Then I can listen to the films in original English language. But the recording is always in French dubbing.
What am I doing wrong ?
Mickha
North West
Check the william-1 post, number 23 in this thread:
I would also check out One HD, on 19.2E, as this also broadcasts an English soundtrack, on some television shows, including Doctor Who, and Doctor Who classics, and is FTA.
Rutep
Hotbird 13 east
Iceland
I do not have a motor to move the disc to 19,2 east, it is pointed at Hotbird at 13 east.
We can sometimes listen to films in original language on Arte whether it is English or Icelandic etc. but to record it in that original language does not work.
I can set the audio in menu on "language" as priority or "dolby digital". Neither affects the recording, it seems...
Try the recorded file on a computer using a player like VLC. If the original audio channel is available then it's a problem with the playback on the Amiko.
Mickha
North West
Have you checked the audio option when playing the recording?
When you record something you can record multiple soundtracks, and select one during playback.
You might consider a 6 degree monoblock LNB, so you can get 13E, and 19.2E.
Rutep
Hotbird 13 east
Iceland
"a 6 degree monoblock LNB"
I wonder if the quality of viewing from either satellite is affected using this equipment ?
Certainly I will consider getting it.
I remember I could watch programs from both Astra 19,2 and Hotbird 13 when staying in Germany. In Italy also I think.
Must have been then due to this tool !
rodscha
i confirm this,here in south France,monoblocks work fine.
Then,in Iceland the angles between Astra & Hotbird must be different...local electro shops must know how to do things.
Check with Spanish,Italian immigrants ,they ll sure know
An extra LNB, multi LNB bracket & DiSEqC switch will perform better than a monoblock.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
In Paris (France) the angular difference between 13.0E and 19.2E is about 6.8 degrees,
In Reykjavik (Iceland) it is about 6.5 degrees.
So the difference between the 2 locations is rather small.
As in the monoblock LNB, the LNBs do not touch, that means that you might also use two separate LNBs.
However, it might be difficult as LNBholders often are rather thick; so not allowing LNBs to be close together.
That is the advantage of a monoblock LNB: it allows two LNBs to be close together.
But the distance between the LNBs must fit the dish (effective focal length) and the angular difference at your location....
@Rutep : Did you check the satbeams of 13E and 19E at Iceland? If an 80cm dish would be big enough for the signal of 13E and 19E?
Greetz,
A33
Mickha
North West
You can find a lot of classic movies on Youtube, which, in a lot of cases are free, and old TV series on sites like Dailymotion.
I recently downloaded the original My Man Godfrey, from Youtube, and viewed episodes of Rumpole of the Bailey, uncensored, on Dailymotion, you would be amazed how many television shows are edited, on British television, which you can find on the internet, uncensored.
I also tend to use KODI, on my VU+ Duo2, as I can download some films, like Drive Angry, Riddick, as well as old TV shows, like Agatha Christies Poirot, and many more. There are a lot of options, these days, for viewing, that don't rely on satellite.
I never watch any terrestrial television, and tend to watch a lot of Youtube channels, like Beau of the Fifth Column, Lehto's Law, MSNBC, CNN, The Young Turks, Brian Tyler Cohen, Rich rebuilds, Samcrac, Audit the Audit, The Institute for Justice, and numerous others, when I have time.
Rutep
Hotbird 13 east
Iceland
Something is wrong with the EPG on Arte.
I can only see the next program, not the schedule for the whole week.
Can you see it ?
I thought it was maybe related to my old receiver but I can see the schedule right of Deutsche Welle for example.
Can you see it ?
Which satellite & frequency?
Rutep
Hotbird 13 east
Iceland
Greetz,
A33
Nobody here knows about monoblock but LNB holders are known. How can I find out about the satbeams ? LyngSat Maps
