Help Required Connecting D15 via WiFi/LAN
hullmod
dr.hd
hull
i am confused it is a d15 and want to connect to the internet with wifi or lan?can anyone help please
Connect an ethernet cable from the back of the receiver to a free port on your router?
Retired Mod
www.timo.me.uk
If you want to use wifi you need to use a wireless adaptor but a direct connection with an Ethernet cable would be more reliable in my opinion.
hullmod
dr.hd
hull
it has got lan port on box,i am so confused lol,do i go from lan to lan or ethernet to lan?
smoggy07
It's the same thing for what we need
get a cable that will go from the box to the router and you are good to go (make sure it's not a cross over cable though), to make things easy, take an existing cable from a pc/laptop you already use on the internet and plug that into the box
Retired Mod
www.timo.me.uk
Ethernet cable (sometimes also called a network cable or CAT5) is what you use to connect devices together on your LAN (Local Area Network, ie the network in your home).
hullmod
dr.hd
hull
thanks mate
