Pete R
- Jan 17, 2009
- Age
- 77
Humax HDR
Panasonic Viera TX-32LZD85
Panasonic DVD Recorder DMR-ES10
- Wirral U.K.
Hi.
Apologies if this isn't the right place to ask this question but I've tried to find somewhere more appropriate for some time without success. Panasonic and Humax Support have been "less than helpful", perhaps because my question is so simple.
I want to get the best out of my new Humax HDR and need help with connections with the other AV components.
I've presently used the HDMI cable from the Humax to the Panasonic Viera TX-32LZD85. (HD broadcasts are stunning!) I use the Humax remote to control both.
I also have a Panasonic DVD Recorder DMR-ES10 which I would like to integrate into the system. Currently I've just used a scart cable to connect it with the TV but wonder if there is a better way.
Thank you, I guess you realise I'm a bit of a novice.
Pete R.
Pete R.
