- Jul 26, 2003
- Location
- Scottish Borders
- Scottish Borders
Yah well done - finding ANYTHING is the difficult bit!
However you need to check that you have actually found 5E - check your channels against this list (you wont have all of them - just the stronger transponder on the Europe beam)
http://www.flysat.com/astra4a.php
If it is 5E then move around the arc one satellite at a time
http://www.flysat.com/satlist.php
Mark the dish up with indelible pen, tippex etc so if you get hopelessly lost you can quickly reset & start again.
