EDISION PRIMO IP S2 H.265 HEVC MULTISTREAM
use file live_prog for channels & satellites list , lamedb only for view in editor.
I don,t understand this. Can somebody explain this or where can i find the file live_prog.
When you save your channel list in backup & recovery you will see a new menu:-
Settings export to USB
Settings import to USB
Import settings from network
Dump firmware
Select export to USB then tick what you want to save from this list:-
DVB channel list
System settings
Stalker
IPTV
Biss keys
CAM settings
OSCAM
WEBTV
Select DVB channel list to USB stick,
When you want to reload via USB stick in Backup & recovery
select import settings from USB stick:
You will see USB Disk1:/dev/sda1
Selecting this option opens the file to reveal several options:
Select SX88+_2018_10_22_1.04.72_0.dbase (This is the name of the file that I have saved today) & press OK,
This file contains the file live_prog 324KB this is the DVB channel list.
Plepkeshenkie
180 cm channel master en 150 cm prime focus dish
Holten The Netherlands
Ok thats clear but what i mean is how can we edit the channels. Is there a channel editor for.
I have not seen a channel editor for this system as I do all my editing in the receiver via the RCU I have not dug very deeply to find the channel editor if it does exist,
What I did find useful was by transferring the satellite channel list from the Octagon SX88+ that runs in sequence for example:-
53 east to 30 west,
Whereas the Edision started at 19.2 east then 13 east followed by the other satellites I can only think this is for 2 to 3 satellite fixed dish set up's,
I will upload a channel list for these receivers 53 east to 30 west maybe you & some others will find this helpful.
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Hi everybody,
Yesterday I turned my dish to Hispasat 30W. I scanned the satellite but I only found a couple of television channels. and some radio channels. I was watching whilst the Primo was searching and I saw a lot of times that he found a transponder in use, he gave excelent signal strenghth and quality but he didn't find any tv nor radio signal. I did a blind scan and asked to search all the channels, also the encrypted ones. Has anyone the same problem with the Edision Primo?
I used the latest .62 firmware.
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Also,
Has anybody experience with uploading firmware from the Octagon SX88+ into the Edision Primo? I saw on another forum that the Octagon SX88+ firmware .70 makes it possible to watch the spanish TDT channels on Hispasat.
EnoSat
enosat.euweb.cz
Slovakia
U2C Denys H265 , Octagon 88 , Ineos ZX4 , EDISION Primo IP S2 , HIREMCO TURBO IPTV , Golden Interstar ALPHA X -> one manufacter , some providers
Ch List EDISION PRIMO IP S2 H.265 HEVC Multistream by William_1
This motorised Satellite TV Ch list covers 53 east to 34.5 west in sequence,
Use this Channel list for the following receivers:-
Octagon SX88+ H.26H.265 HEVC HD Multistream,
Octagon SX88 H.265 HEVC HD Multistream,
EDISION PRIMO IP S2 H.265 HEVC Multistream,
Golden Interstar Alpha X H.265 HEVC HD Multi-stream,
Other H.265 HEVC HD Multi-stream receivers that this list are compatible,
Thanks to Enosat for this info of compatible receivers below:-
U2C Denys H265 , Octagon 88 , Ineos ZX4 , EDISION Primo IP S2 , HIREMCO TURBO IPTV , Golden Interstar ALPHA X.
This edition fully updated on 23nd October 2018.
Including:-
ERT 1,2,3 & HD on 39 east,
36 east updated,
21.5 east updated
Multistream updated @ 4.8 east,
RTS package has left 4.8 east,
3 west feeds for CL added, Capri TV transponder active same as 11 west,
RIT has left 12.5 west,
  • Ch List EDISION PRIMO IP S2 265 HEVC Multistream by William_1 for Oct 23rd 2018.rar
  • Ch List EDISION PRIMO IP S2 265 HEVC Multistream by William_1 for Oct 23rd 2018.zip
I've just fired up the Edison for the first time (been busy with U3A and Tax Returns stuff for a few days), and updated the f/w after the prompt but not yet the channel lists - so I only have Hotbird and Astra 1 ATM, with the Rx driving the TD110 via USALS.
What "flabbergasts" me so far is omission of a direct "Sat" selection button on the R/C, and thus the clunky and long-winded method for changing satellites: press "OK", "Info" and then "Satellite" before you get the list of satellites from which you can select the one you want - or am I missing something "obvious"??
I agree, this is a bad oversight on Edison's part, and I find a pain in the backside!
FWIW, I did try to remap one of the coloured buttons to be "Sat" but even that doesn't have that option! Really p*****d off with this box already:N
Might even try to return it and get an SX88+ - or even a Golden Intersat Alpha, but is that the same as the Primo S2????
Mooncamm
1 metre Gibertini dish, Octagon SX88 Receiver
Lincolnshire
I confirm that the SX88+ has got a nice Sat button.
I have the SX88 and that also has a SAT button
So I see!
Each to their own - Personally I find it a joy to use and so does SWMBO. It has pride of place in our PAVVP.
