Elavation system for 90cm with orginal polarmount
Snuffer
Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg
Amsterdam
Yesterday i finish the small project for doing elavation for 90 cm Fibo with orginal mount.
It works like i think and will.
Monday i hope i can change the last think for it (when theworkplace is open) if not it must be done 4 Jan 2008.
I will make a small bearring insite extra.
Will make some photo's later to day and put them here.
idea are elevation from orginal clarck belt 0 to 10 degrees up and down and keep the orginal mount no jaeger 1224 system.
Ron
Snuffer
Amsterdam
First picture of system.
It works now we go optimize it with bearrings etc.
CROSSBONES
S.Wales
Nice! Its great seeing new ideas for the fibo`s
Snuffer
Amsterdam
Here are the first photo of a working setup.
I find out that the Alu.corner i use is not stabel so i must change that tomorro.
CROSSBONES
S.Wales
Very nice! Simple idea but works great!:)
Thanks for showing;)
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
Nice work!! looks like a really clean assembly.
So you have one motor for side movement and one for up and down?
Another Question: If you would mount the original polar mount at an angle depending on your position in the world, would that not do the job (keeping the dish on the C-Belt) without having to use another motor?
nowready
dreambox DM800SE;
moteck diseqc rotor 90 cm ;
analog rotor 133 cm prime focus;aston diseqc2analog rotor converter;stab mp02 rotor control;
The Hague The Nederlands
"If you would mount the original polar mount at an angle depending on your position in the world, would that not do the job (keeping the dish on the C-Belt) without having to use another motor? "
The clark-belt is a circle centered on the earths center
The arc described by one motor disk has a center on the earths surface.
The two can never be completely coincident
Snuffer
Amsterdam
I use that elevation for Feedhunting and as you now 20 W, 3E and 37,5 W are out of the belt they are incl. with 3,8 degrees now i turn my fibo with the orginal motor to 3 E and lift the disch 3,8 degrees and yep picture. so i can see 20 W all time he have 2 degrees i remember.
Thats the idea behind it.
T_G
Have a look a this:
"...The largest 40" Primestar dish is on a Poor mans H-H mount!
I off-set the mast to match my exact latitude (45º) then when I move the dish from side to side it follows the Clarke Belt!"
ww.satellites.co.uk/satellite/693679-post1.html
Snuffer
Amsterdam
Today i have with my hobby friend Feedhunter Rini doing some test in garden with a 99 Greg.
20 W are not in clarkbelt atfter change the dish a little down we have 80 % Q from it so he are below the belt. we found in belt no TP and when use the system we found 11 TP's.
Also we look on some ather sat's and found that on 10 East some % gomming up. ( not realy intrested the TP are 60 % and good picture bud when use the system we see 82%.)
Soon as the wether are better i change my system for this Elevation.
Up to the next project.
Rotor control for 36V Fibo motors by PC with standalone system.
Nice idea there Snuffer, what are you using to operate the actuator?
Snuffer
Amsterdam
On this moment i use a Philips SCC 203/01
a orginal box for Philips gregorian made by FIBO.
If you are intrested i have the orginal Philips catalog with pictures perhaps to scan for you its a collectors item arround 20 Years old now.
I will operate by the PC soon. so 2 controls in 1 programm.
Yes, keep us updated on progress. A picture of the box showing the front/back would be interesting.
Snuffer
Amsterdam
From the catalogus i will make picture with Camera battery are empty
This weekend i have photo's of it
  • Doc1.doc
