Electronic Programme Guide
lingofreak
1 metre dish. Nokia Mediamaster 9500s used for FTA European channels.
Brighton, UK
Hi, this is my first post so hope I have got it right. I am using an old Nokia 9200 to view European channels but gradually most on screen information has disappeared with the exception of RAI 1,2 & 3.
I need to buy a new receiver as mine does not have a timer and most if not all new ones do. My question is this :- I can't find any information about EPG, yes they all have it but, 1 is it up to the broadcaster or the software? 2 is it only available on subscription I watch free to air channels? 3 Would a receiver with PVR work with EPG as simply as my terrestrial Humax PVR receiver?
I hope someone with experience of EPG can help me. Thank you.
Make sure the time is set correctly on your receiver - my Echostar loses the epg info if it gets more than a few minutes out of synch
Its carried on both fta and scrambled channels, and is up to the broadcaster to provide.
lingofreak
Brighton, UK
Thanks, my Nokia is not the best timekeeper, I get info on Rai the Italian state channels at all times hence my query is it up to the provider or the software, I guess I won't know untill I get a new receiver - a Manhattan or Technomate possibly.
