Express 80 (will be 80E) & Express 103 (will be 103E)
11106 V-active now
tempo
47.5N, 42.2E / Russia
Test carriers
10982 H
11106 H
11106 V
11160 H
11169 V-activated now
tempo
Test carriers
11169 H
11169 V
There are only 4 TPs in the band 12500-12750 MHz
~12565 H
~12565 V
~12685 H
~12685 V
11669 V is active again atm
tempo
According to the last TLE, Express-103 sat is now stabilized on GSO at 102.9e position, ready for testing.
Unfortunately, I can't monitor the testing of 103e, since there are obstacles on the way.
11668 V-test carrier now
tempo
Well, they've started to test C-band transponders now.
3825 L is active atm, the bandwidth is around 50 MHz (received in Belarus, not my info)
P.S. There is Left Circular polarization on both plots, since a single-polarization LNB is used there.
The testing at 103°E seems over, Express-103 started drifting a few days ago and should be at 96.5°E on March 8.
I'm curious if the name will be changed there!
Transponder tests activated.They appear and disappear after a while.(all credit goes to @wellikan.Thanks)
10962 V,14000,3/4,
10980 V,14000,3/4,
109898 V,14000,3/4
Express-103 did not stop at 96.5°E as was expected.
Maybe it will continue to 90.0°E, which is a slot shared by Gazprom (Yamal) and RSCC (Express).
Correction: Express-103 has actually stopped at 96.5°E on March 8.
Apparently a swap happened for several days with another nearby dead satellite.
cybertomanek
Laminas AS-1500 +Jaeger SMR 1224 80E - 45W
U2C Denys H.265
Poland
Here We go, North West Poland :)
dreamsat
germany
yes, here also:Y
MCelliotG
Thessaloniki, Greece
Yes!!!
The signal is fairly good in my location, considering the alleged footprint!
In my area is also really good signal from the Express-80.
In my area is also a really good signal from the first transponder activated at 80.0E :Y
dreamsat
germany
Now the snow is off the antenna. The values are significantly better.
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
Here with 1.2m
