Newbie Here Freesat 4k recordable LNB issue
Raymond6045
Sky dish for SKY Q (2020) connected to Freesat 4k recordable with a Standard LNB 2cables
Essex
We had SKY Q installed in 2020, when our daughter and her family moved in. Last year they moved to their refurbished house. We purchased a Freesat 4k recordable box and connected to 2 cables from SKY dish. No picture, so we purchased a standard LNB 2 cables (replacing SKY wideband LNB, model EL06) and we currently have service.
However, we wish sometimes to record 4 channels.
What Wideband LNB do we need to buy to enable this to be done?
It should have worked with the Sky Q wideband LNB. First thing I would do is reinstall the wideband LNB and do a 'reset settings only' reset. Be aware that a full factory reset will delete all your recordings.
Raymond6045
Essex
Thanks. I’ll try that tomorrow. Correction, SKY wideband LNB is Model EL026.
Which Freesat 4k box have you purchased ?
Raymond6045
Essex
Freesat recordable 4k TV box
Raymond6045
Essex
Freesat/ OEM M ODEL FS AR 01C/ ps5431efs capacity 1000GB.
PURCHASED FROM Currys
If you connect to a Wideband LNB and it doesn't work at first attempt, just reverse the cables, as if like the Sky Q, the Vertical and Horizontal need to be connected to specific ports.
Raymond6045
Essex
i have changed back to SKY LNB and got Freesat box working. Went into Freesat settings and Wideband LNB is recognised.
Completed a “reset settings only”
Hopefully this allows 4 channel recordings.
Thanks for your assistance.
Thanks for letting us know :)
I understand you can record up to 4 channels, but when recording 4 you have to be watching one of them, you can't record 4 channels and watch a 5th live, but you can watch something already recorded.
