Help for gilbertini 1.5
rayo77
I have dish 2.3 famaval
Morocco
I have a dish gilbertini 1.5. I do not have its original shield. I want someone to help me and give me the measurement of the shield’s distance and the LNB distance to the focus of the dish. Thank u
Shield ?
The feedarm is not a straight item btw.
Technical Info
Size: 155.0 x 166.0 cm
Offset angle: 21.3°
Pole mount: 55 - 100 mm
Elevation range: 21.3°
Noise figure at 30° elevation: 33 k
Frequency range: 10.00 - 13.00 GHz
Antenna gain at 10.95 GHz: 43.3 dB
Cross polarization decoupling: > 30dB
Wind pressure at 120 km/h: 235 kg
rayo77
Morocco
Shield ?
Technical Info
Offset angle: 21.3°
Thank u for respond
I want to know the distance Rod?
Arrow pic
What is the distance in metres?
Thank u for respond
Arrow pic
The one on the imagery looks to be correct, though you have only taken pictures from underneath, a side view would be useful..
So are you going to be constructing something similar, along with the correct feed arm support points since they also look genuine ?
EnoSat
enosat.euweb.cz
Slovakia
I think he will be able to construct only when you provide him with distance and not technical parameters
rayo77
Morocco
The feed arm support points are not original. I am missing a signal, so I want to know the correct distance
It is not a single parameter, so whatever has to be provided will be more than the o/ps single dimension request.
I would suggest they return to site and take measurements of the connecting arms to whatever survives since it now an archaeological quest.
Contacting Gibertini Italy directly should provide solutions, a product part /cost/delivery etc. ( and may be better than blind questions on a forum)
EnoSat
enosat.euweb.cz
Slovakia
Try contacting here, they may still have this dish and provide you with the dimensions.
Or write to satesco, who also uses the 1.5 dish (I think Gibertini too)
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
really a shame i used to own this dish and did many experiments with it , find this datasheet maybe will help you find what you are looking for
  • GIB-OP150S.pdf
rayo77
Morocco
Thank u for info
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
From the specs of the Gibertini pdf that @pipino posted ( flatfaced 150.0x161.0=21.3* offset, 70.0* illumination ), the focal point would be 163.23 cm from the top of the dish, and 104.74 cm from the bottom of the dish.
So you could find your arm position, and side-arm position + length, from that.
However, I would always take measurements from the dish itself, to do the parabolic calculations on. Specs "on paper" should not be trusted, without some checking... :oops:
Greetz,
A33
a33
XSAT410
Rebox RE-9000
The Netherlands
@rayo77 :
So, did you receive side arm length specifications from somebody?
Or are you ready or willing to do measurements on the dish, to really check?
For precise calculations, I would recommend to calculate on height, width, and depth at the center (of parabolic surface, excluding the rim).
A more rough assessment could be done by measuring from the bottom of the dish to about 3 cm in front of the center of the LNB holder. If that distance would be about 104-105.5 cm, chances are that the above specs calculation is not very bad...
greetz,
A33
